Need Key FOB
Old Feb 25, 2004 | 07:04 AM
skytower31's Avatar
Need Key FOB
Is there a inexpensive way I can get a replacement FOB and program it myself? This is for a '03. Thanks!
Old Feb 25, 2004 | 07:29 AM
s_hinerman's Avatar
ebay has them all over for like 10-15 bucks and some of them include programming instructions and if not i'm sure somebody on here knows how.
Old Feb 25, 2004 | 07:39 AM
skytower31's Avatar
I read on a different post that there are instructions somewhere on the site but I couldn't find them in the 5th gen FAQ's. I found all those on ebay also...much better than getting it at the dealer!!!
Old Feb 25, 2004 | 04:19 PM
wavedog's Avatar
I got this somewhere off the org a while back hope it helps..
For 1998-2002 Maxima, Pathfinder, Sentra, Altima, and Frontier Vehicles 2002 Quest and Xterra Vehicles:
1. Programming Procedure:
A. Get in the vehicle. Close and lock all doors using the driver's power door lock-unlock switch.
B. Insert and remove the ignition key more than 6 times within a 10 second period (at a rate of one insertion/removal
cycle per second). The key should be withdrawn from the ignition key cylinder completely each time it is removed.
NOTE : Do not rush the insertion/removal key cycling process.
C. Turn the ignition key to the "ACC" position. The ignition key should remain in the "ACC" position throughout
the remainder of the programming, including programming of additional remote controllers.
NOTE : Do not press the button more than one time in the above step. If the button is pressed more than one time,
the programming procedure will not be successful.
The hazard warning lights will flash twice when this step is accurately completed and programming is successful.
For 2000 Quest vehicles, the side marker/tail/license lamps will flash twice when programming is successful.
E. If you are programming only one remote, proceed to step 3A. If programming additional remotes, continue with step 2A,
below.
2. Programming Additional Remote Controllers (Maximum of 4 Remotes):
A. Remain inside the vehicle after programming the first remote.
B. Use the driver's power door lock-unlock switch to unlock and then lock the doors.
C. Press any button on one of the additional remote controllers one time.
The hazard warning lights will flash twice when programming is successful. For 2000 Quest vehicles,
If there is more than one additional remote to be programmed, repeat steps 2A through 2C above for each additional remote.
3. End Programming:
A. Remove the key from the ignition.
B. Use the door lock-unlock switch on the driver's door to unlock the doors.
Open the driver's door to complete the programming
C. Check the operation of each of the remote controllers
by locking/unlocking the doors with each remote controller you have programmed.
D. Press any button on the remote controller one time.
Old Feb 25, 2004 | 06:04 PM
skytower31's Avatar
Does this work for '03's?
Old Feb 25, 2004 | 06:55 PM
3Pedals_6Speeds's Avatar
wavedog - I don't see in your instructions when the person is supposed to push the button (and which ones) on the remote? You said for additional to do something, but when for the 1st? I assume after the hazards go, but........
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
