Camber Adjustment/Eibach
Old Mar 5, 2004 | 04:36 PM
nfisher50's Avatar
Just ordered the Eibach lowering kit with illuminas ($700 southwestauto), can't wait!! Do I need to worry about the camber kit?? Will they be able to adjust everything at the shop?
Old Mar 5, 2004 | 04:43 PM
2kGLE's Avatar
Dont worry about a camber kit with that set-up. Thants exactly what im running and i didnt even need an alignment. My alignment was just fine.
Old Mar 5, 2004 | 06:24 PM
Ammi's Avatar
350 Detroit Muscle
How did you know your alignment was fine? Just because your steering wheel is not off center doesn't mean your alignment is in spec.
You always get an alignment done after a suspension mod.
Old Mar 5, 2004 | 07:03 PM
2kGLE's Avatar
My mechanic checked it out, and the car goes perfectly straight on flat road at 100. That and my other mechanic who usually does my alignments took it for a test drive to check out my suspension mods and my alignment. Ive had my alignment messed up and corrected enough times that I can tell if its off by much. I will get it aligned one of these days, but it seems fine and my tires are wearing fine so i dont really care at the moment.
nfisher,
Im certainly not saying you shouldnt get it aligned. Im just saying dont worry about the camber kit. I dont think you will need it.
Old Mar 5, 2004 | 07:18 PM
Ammi's Avatar
350 Detroit Muscle
As for me, I like to see numbers printed out on a sheet so I can look at the before and after. I recently had alignment done (regular maintenace) even though my car was going straight but after looking at the numbers (camber, caster, toe, etc), they were out of spec.
With Eibach, you will not need a camber kit. You will be just fine.
Old Mar 5, 2004 | 07:37 PM
2kGLE's Avatar
I like to see numbers too i just didnt see why i should bother paying for an alignment when two trusted mechanics made the measurements and test drove the car, and i would want another alignment after the suspension settled. I will be getting an alignment to make sure once the im sure the suspension has settled completely. There isnt much you can adjust on our cars anyway unfortunately. There rear alignment is not adjustable and you cant change the caster or camber in the front, just the toe.
Old Mar 6, 2004 | 02:38 PM
Ammi's Avatar
350 Detroit Muscle
alignment shop changed my caster.
Old Mar 6, 2004 | 04:17 PM
2kGLE's Avatar
Can you scan those alignment sheets where the mechanic changed your caster? I would be really interested to see that.
Old Mar 6, 2004 | 10:07 PM
Ammi's Avatar
350 Detroit Muscle
oops. I read it wrong. It was Toe and SAI.
matts95max
Apr 23, 2025 10:44 AM
Dan93se
Apr 7, 2001 02:46 PM
sachin98max
Feb 24, 2001 11:35 PM
I30CeFiRo
Dec 28, 2000 09:25 PM
ZuMBLe
Nov 1, 2000 07:39 PM
