***NEED HELP*** Car has not power
Old Mar 9, 2004 | 01:42 PM
Link9510's Avatar
Hey guys are was driving today and my check egine went on adn my car lost all of it power.. Felt really bad and on the light it started to smell like ****.. Like ROTIN Eggs... Any idea what i could be my car is a 2000 max se and with 70k miles
Old Mar 9, 2004 | 02:01 PM
chinaonnitrous1's Avatar
sounds like you burnt something...........so car wont start? wont move...wont idle? your pretty vague.
Old Mar 9, 2004 | 02:02 PM
Link9510's Avatar
nah.. drives but it just feels like a 4 beater not a 6 any more but... and sometimes the checkengine blinks and it that when it suxs but if it goes off it drives like a max agian
Old Mar 9, 2004 | 02:09 PM
up4surf's Avatar
I think I know what smell you are talking about. People have told me that the smell is from a cat. going bad. This could explain the smell and loss of power from blockage. do you have any mods?
Old Mar 9, 2004 | 03:04 PM
if the CEL is blinking, thats usually a misfire...thtas bad...hahahah
Old Mar 9, 2004 | 07:37 PM
Link9510's Avatar
But see it doesnt all ways do that
its only once in a while
and have no mods and only use 93..
Old Mar 9, 2004 | 08:44 PM
03maximan's Avatar
Coil packs? getting bad MPG too probably?
Old Mar 10, 2004 | 11:25 AM
Link9510's Avatar
Thats what i was thinking maybe the coils.. But i had a 95 before it went 136000 never changed any coils or anything
Old Mar 10, 2004 | 11:31 AM
desperado_45's Avatar
Does is start easily or with difficulty?
Old Mar 10, 2004 | 12:00 PM
NewLoveI30's Avatar
Posted by Link9510 - Today at 11:25 AM
ive Heard that the 2000 coils can be problematic. Go to the dealer and see what they say. Hopefully you still have some warrantee left. Ask the dealer about the TSB on the coils.
Ive also heard that if your coil packs have a silver dot on them that they are the new ones that dont seem to have problems. You could check those.?
Good luck
Old Mar 10, 2004 | 05:51 PM
Link9510's Avatar
it starts fine
Old Mar 10, 2004 | 07:45 PM
Link9510's Avatar
Here let me be more specific...
It drives very well untill some times it will lose alot of power and you will feel alot of vibartion in the shifter and on in the car from the engine.. And thats when the SES light goes on... But if you drive it off it works fine again.. and it just happens when it feels like happen..
One more question is there a TSB for the coils on the max.. I hread there was
Old Mar 10, 2004 | 09:32 PM
03maximan's Avatar
http://maxima.theowensfamily.com/tsb/NTB99-075.pdf
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Maybe one of these
Old Mar 11, 2004 | 03:35 AM
Link9510's Avatar
Will it work if your Warranty has already ended?
Old Mar 11, 2004 | 06:46 AM
Link9510's Avatar
So what do you guys thing the problem is.. And how much does Autozone want for ses read
Old Mar 11, 2004 | 08:37 AM
03maximan's Avatar
Get the computer scanned, it should have stored a code sayin what the problem was, and yes autozone should be able to do it, usually it's free.
Old Mar 11, 2004 | 08:54 AM
Link9510's Avatar
Yeah i will shot over there today see what they can say because when i started it this morning it had the SES light on
Old Mar 11, 2004 | 09:43 AM
CRIS_Y2K_SE's Avatar
im having the same problem i know the smell he is reffering too, it was when you push the car hard and then you slow down a bad smell comes in (like rotten eggs). Also the car will rumble like if it is going to turn off .I took it to autozone and they pulled this code:P1320 coil miss fire. So im guessing thats your problem as well. Talk to DaveB about this he will hook you up.
Note: I have the same car as well .
Old Mar 11, 2004 | 09:46 AM
Cutler's Avatar
MAF or Coils(get some new coils, replace all 6, it takes 20min to do all 6)
Old Mar 11, 2004 | 10:26 AM
5spd2000max's Avatar
It's 100% your CAT i had the same problem with mine, during cold days I had hard time getting the car started, and when i hit the gas hard it had no power and it smelled like rotten eggs. And the oxygen sensor gives u that SES light.
Change the CAT and the problem will be solved
Old Mar 11, 2004 | 12:29 PM
Link9510's Avatar
Nah i just got back from autozone they pulled two numbers P1320 AND P0301
One is for missfire in cynlider 1 and other one is ingintion system problems or something i cant exaclty rember..
Old Mar 11, 2004 | 12:32 PM
Link9510's Avatar
One more we own a Body Shop and we got a I30 2000 standing around for parts... you think if i pulled it off there they would work its only got like 20k on the enigne. I as far as i can tell they are the same engines..
Old Mar 11, 2004 | 01:00 PM
NewLoveI30's Avatar
They are the same engine, but that also means that they have the same coils. If you replace with these coils you may just have the same problem down the road.
New coils are a different part so it wouldent just be a temp fix.
Old Mar 11, 2004 | 01:03 PM
Link9510's Avatar
I see... But does any one know the mean of the codes exactly... So i can know for futher.. So please post the exact meaning and explain them ... Thanks i really thank you guys for all your Help..
Old Mar 11, 2004 | 03:03 PM
Link9510's Avatar
SO any know what Code: P1320 AND P0301
Mean
Old Mar 11, 2004 | 03:52 PM
98i30's Avatar
Have had same problem 3 months ago on 2000 MAX with 40K on it.
Replaced all coils. No problem since.
Old Mar 11, 2004 | 05:13 PM
Blazin247's Avatar
I had the same problem as well. Car shuddering at stops, no power, smell of rotten eggs. It ended up being a misfire, they replaced a coil, it was fine. Now it's starting to act up again and the smell of rotten eggs is still there. I'm not sure if it's more coils, or it's the CAT like others say. Either of these covered under the 60k drivetrain warranty on a 2k?
Old Mar 12, 2004 | 05:57 AM
Link9510's Avatar
well my warranty has already ended so i just go to d oit on my own
Old Mar 12, 2004 | 12:30 PM
MAXSIE's Avatar
I bet $50 that it's the MAF.
Old Mar 12, 2004 | 06:33 PM
Blazin247's Avatar
Anyone know if it's covered under the warranty? My guess is no but you never know.
Old Mar 12, 2004 | 07:53 PM
jimkim2004's Avatar
Uh... cylinder misfire usually means bad coils. If it's the coils, you owe me $50. I take paypal or MO. Personal checks need to wait one week to clear.
Old Mar 12, 2004 | 08:19 PM
Link9510's Avatar
well who collects the money on the bet??
I chagned my Spark Plugs and Coils and Right Front Bearing to day and the Brakes and that car drive like i just bought... Not that the bearing and the Breaks help the engine
Old Mar 15, 2004 | 05:40 AM
MAXSIE's Avatar
Paypal will do, just fill out my simple account verification form... J/K
Damn, thought I had this one.
Good call Sparky!
Old Mar 15, 2004 | 01:00 PM
Link9510's Avatar
Yeah man the Car runns like a NEVER before now i am LOVING IT
Thanks FOR ALL THE HELP
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
