Light Predetonation -- Causes
Old Mar 14, 2004 | 08:35 AM
2002 Maxima SE's Avatar
I'm getting a slight predetonation sound coming from my engine. It's when the engine is not under load and usually cruising (foot off gas) from 20mph to 40mph. It is very light, but I can here a rattling noise.
This started after I removed the front spark plugs, put some anti-seize on the thread and reinstalled them (torqued to 15 ft pds). Are the coil packs designed only for certain cylinders? Could something else be the cause of this noise?
Old Mar 14, 2004 | 10:27 AM
03maximan's Avatar
Predetonation is a ping or in worse cases an knock,
is that what you are hearing?
Old Mar 14, 2004 | 01:07 PM
njmaxseltd's Avatar
And also only happens when your engine is under load.
If your hearing noise under a no load condition, it's not ping or spark knock.
Old Mar 14, 2004 | 01:13 PM
Sounds just like a ping (not a knock)...very faint though.
Old Mar 14, 2004 | 05:33 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
If it's not under load, then it's probably not pinging. It could very well be the "missing mystery screw" from the power valve, which would suck b/c you'll most likely need a new engine...
Old Mar 14, 2004 | 06:18 PM
No, I checked that and the throttle body yesterday. Both screws present. Could this happen if the spark plugs were not torqued down tight enough?
Old Mar 14, 2004 | 06:29 PM
03maximan's Avatar
I tell ya what I would do, Take each one of those 6 puppies out
and re-check plug gaps, and at the same time
make sure torque is correct, and coils are on good.
Old Mar 14, 2004 | 07:32 PM
OT n00bs FTMFCSL
Could be the precats breaking up...WILLSE had this problem with his precats. Not a very good thing...
Old Mar 14, 2004 | 07:59 PM
What is the correct torque? The manual says 14 - 23 ft pds. I applied 15 ft pds.
Old Mar 14, 2004 | 08:01 PM
How was he able to diagnose it? You know what Nissan will say. "Normal"
Old Mar 14, 2004 | 08:59 PM
03maximan's Avatar
15 should be good, but check your gaps.
Old Mar 15, 2004 | 11:35 AM
TitaniumSE_MAX's Avatar
Ping
Yes, I also get pinging on light load around 40mph on my bone stock '03 SE. I've had it to the dealer twice. typical response... normal, no problem. I always run Mobil or Sunoco 93. I've had the ECU re-flash and all the known TSBs done. Not sure what else to do.
Old Mar 15, 2004 | 12:00 PM
Interesting. Let me ask some questions of you:
1)Any changes to sparkplugs?
2)Which TSB/Recall have been performed?
I'm leaning toward several conclusions:
1)Bad tank of gas
2)My last recalled was rushed due to incompetent dealership. Something may be loose under the intake manifold causing a "ping-like" noise.
3)MAF is slightly dirty
4)Plugs loose/Coil not making contact
Old Mar 15, 2004 | 12:14 PM
The pinging has been going on for several months. I recently had the ECU reflash and the cam sprockets done. No changes to the plugs. I imagine the only way the plugs would make a difference is if you changed the heat range to a hotter plug. I think it is a lean condition that is inherent to the stock ECU closed loop mode, while trying to maximize the fuel economy and minimize the pollution. I fix it by putting my boot to the pedal. The pinging goes away when I give it a little more throttle. My car only pings when I am very light on the pedal around 40mph and the trans is in a higher gear (maybe 4th).
Old Mar 15, 2004 | 12:22 PM
True, true. It is kinda odd. I wonder if one of the reflashes has caused this?
So far, I have had all recalls and:
1 Reflash for hesitation
1 Reflash during O2 sensor replacement
1 Reflash for sunroof (probably not related, but programmers make mistakes).
I don't recall hearing the noise until after my last recall, however I had the hesitation TSB done about 2 weeks prior so it is hard to say.
This is exactly what mine is doing. A little throttle and it goes away.
Old Mar 15, 2004 | 12:29 PM
It pinged before and after the last ECU reflash.
I had it for the hesitation TSB.
Funny you mentioned the sunroof. They replaced the slide switch on mine to fix the sunroof TSB. Dang thing opened by itself while it was parked at an airport. It was a cold snowy day, so I couldn't possibly have left it open.
Old Mar 15, 2004 | 12:33 PM
My sunroof refused to close and made a noise twice like it wanted to open. I tried resetting the module but nothing worked. After the reflash, no problems.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
