rear pads for 2k2-2k3
Old Mar 16, 2004 | 05:36 AM
NT2SHBBY
I have been looking for ceramic rear pads for my Powerslot rotors due to the fact that metal pads make way too much noise for my liking but no one seems to have applications for the 2k2-2k3 maxima yet it seems they have them for the 2k-2k1 maximas
my question is, aren't our rears the same as the 2k-2k1 maximas??? so if this is the case can I get away with rear pads from a 2k-2k1 maxima??
thanx for your responses
Old Mar 16, 2004 | 06:33 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
I hate to say it, but you need to do a search. I posted on this very subject last week.
Hell with it, check this link to the very parts I used (and am very happy with, I might add)...
http://www.partsamerica.com/SelectPa...+Shoes%2C+Rear
Old Mar 16, 2004 | 06:42 AM
NT2SHBBY
ceramics aren't in stock.....so are the 2k1-2k rotors in the rear the same as ours???
thats what I wanna know
Old Mar 16, 2004 | 07:09 AM
OT n00bs FTMFCSL
It only takes a day to get them in. Just go to a store and order them. I had to do that as well...
By the way, that's for my zipcode, so try changing it to yours and see if they are in stock near you. And from what I've seen, the part #'s differ (even though I thought they were supposed to be the same).
EDIT--> They part numbers do not cross reference. Here's the link for 2001 rear pads.
And you do know that you could have done this yourself by just changing the year of the vehicle in the parts search engine...
Old Mar 16, 2004 | 07:16 AM
NT2SHBBY
I put in my zip code and they come up NOT IN STOCK...what store am I supposed to go to?? Pep Boys and Auto Barn both by me dont have ceramic applications for the 02-03 maxima
will the 2k-2k1 rears fit???????????
does ANYONE know???
Old Mar 16, 2004 | 07:19 AM
OT n00bs FTMFCSL
does ANYONE know???
Do you have Advance Auto Parts up there? That's where the store is for. Also, you could order them online...
And since the part #'s do not cross, I would have to say no, they do not fit. Easiest way would be to just compare pads between the two models...
Old Mar 16, 2004 | 07:36 AM
NT2SHBBY
how do I order them online...the link you sent me wont let me order them....
there is no advance auto parts in NY that I know of
Old Mar 16, 2004 | 08:04 AM
OT n00bs FTMFCSL
The little shopping cart on the right hand side of the item...just click on that, and then click on check out. You're going to have to set up and account with them, but it doesn't take long at all. Just follow the on screen instructions and you'll be good to go.
And if you've never change the rear pads, you don't have to take off the bracket that actually holds the pads. You'll have to disconnect the parking brake on both sides, remove the pistons and such, turn the pistons clockwise to get them to recess back into the caliper, and then just install the pads and reinstall the piston/caliper assembly. Don't forget to keep the lid of brake fluid reservoir open while pushing the piston back in. Then close the lid of the reservoir, reinstall the wheels/tires, start the car, and pump the brakes a few times until you get the solid feel back in the pedal. After that, you're done. take her for a spin.
Old Mar 16, 2004 | 08:06 AM
NT2SHBBY
ok quicksilver...there must be a communication problem here...
THE LINK YOU SENT ME ASKS FOR A ZIP CODE-I ENTER IT AND ADD THE BRAKES TO MY SHOPPING CART AND THEN IT SAYS THERE ARE NONE IN STOCK IN MY AREA
Old Mar 16, 2004 | 08:09 AM
OT n00bs FTMFCSL
Hmmm, now I understand what you're saying...
No need to yell, though. Try some other local zip codes, or just use mine (30052)...then see if it will let you order them. If not, then you most likely won't be able to get them...
Old Mar 16, 2004 | 08:10 AM
NT2SHBBY
ok..anyone else have any ideas here....I'm churning my tires in circles apparently
Old Mar 16, 2004 | 08:18 AM
OT n00bs FTMFCSL
That's about your only recourse for ceramic pads man, I'm telling you (trying to find them online, I mean). Sorry I couldn't help...
Old Mar 16, 2004 | 10:28 AM
MaximaMan77's Avatar
I made it most of the way thru w/out a prob.
Do you have metalics on the Powerslots now?
I had'em on the front of my 99 w/slotted rotors and it wasn't noisy.
Old Mar 16, 2004 | 10:40 AM
00MaxSE's Avatar
Pointy Elbows
I just ordered mine from Rockauto.com. Check they might have them for 2k2-2k3. They have pretty good prices.
Here's the thread that has the discount code and stuff.http://forums.maxima.org/showthread.php?t=294400
Old Mar 16, 2004 | 10:51 AM
LloydBanks's Avatar
NT2SHBBY...they got them down here (Philly). Try putting in 19120 and see if it lets you ship them. If not, it's only a 2 hour train ride down for a blizunt and a cheesesteak.
Old Mar 16, 2004 | 11:04 AM
NT2SHBBY
you offerin to blaze me out??
I'm gonna try again
Old Mar 16, 2004 | 11:16 AM
LloydBanks's Avatar
I'm gonna try again
It's part of the standard tour.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
