can't find 'how to ' on reprograming the visor remote??
PROGRAMMING HomeLink
1. With the ignition key in the OFF position,
press and hold the two outside buttons, and
release when the indicator light begins to
flash (approximately 20 seconds). This pro-
cedure erases the factory set default codes
and does not have to be followed when
programming additional hand- held trans-
mitters.
2. Hold the end of the hand- held transmitter
(from the device you wish to train) approxi-
mately 2 to 5 inches (50 to 127 mm) away
from the surface of HomeLink keeping the
indicator light in view.
3. Using both hands, simultaneously push the
hand- held transmitter button and the de-
sired HomeLink button. Do not release the
buttons until step 4 has been completed.
NOTE:
Some garage door openers may require
the procedures noted under “Canadian
Programming”.
4. The HomeLink indicator light will flash,
first slowly and then rapidly. When the
indicator light flashes rapidly, both buttons
may be released. The rapid flashing light
indicates the Integrated HomeLink Univer-
sal Transceiver has been successfully pro-
grammed.
To program the remaining two buttons, follow
steps 2 through 4.
If, after repeated attempts, you do not suc-
cessfully program the Integrated HomeLink
Universal Transceiver to learn the signal of the
hand- held transmitter, refer to “Rolling Code
Programming” later in this section.
mitters.
NOTE:
Programming”.
grammed.
steps 2 through 4.
Originally Posted by smartazz
search does not work
ef9
09-05-2015 11:18 PM
