2K Maxima, ignition coil problem?
Hey guys, Newbie here. I tried to search for the ignition coil problem but had no luck. It seems I have something chronic going on with my #4 coil. I replaced it about 2 months ago, cleared the error code to get the check engine light to go off, then last week had the light come back on with the same symtoms. Does anyone know how to go about resolving this issue? I have found the TSB #01-059, and the DTC is error code P1320 spark knock. I stoked I found this website!! I talked to ADMAN and he said that Jeff or Toylet or even BigDogJohnX might be able to help, maybe even Kev the Moderator.
Im not able to log on to this site very often during the day, but I can check my email. If anyone could email me I would appreciate it. apeterson@willdan.com
It may not be just #4 it could be an opposing cylinder and the PCM is just identifying #4 as the culprit. If you have the old coil, try swapping out #1 and test for a while etc. Of course you have to make sure the part numbers on the coils match (another brilliant move by Nissan engineers).
Well, I ran it on a scanner today at AutoZone and got the P1320 ign. system misfire again, but this time I got a P0302 code, with says its the #2 cylinder misfire. So I ordered a #2 coil from Nissan-Auto-Parts-Dealer.com for $56.00 including shipping. Not bad, glad it says its the even side again. I will try and swap it around till I find which one it is.
you might as well just change all six, becasue they are all bound to fail sooner or later. i am now having the problem with #6, hopefully i am going to order a set from dave b. next week or two.
Originally Posted by irish44j
Although I have nothing to add, I have to comment that I love it that you've named yourself after a Sir-Mix-Alot song.....classic!
who? is named after the song?
swapmeetlouie.
it's a song from his album "Mack Daddy" (the one with "Baby Got Back" on it....
Sorry no sirmixalot song called 30585
Originally Posted by kpr10is
Lakersallday24
Nov 7, 2024 07:31 PM
kenc15
Sep 25, 2015 06:38 AM
