Max2k1 vs. 2k1 Jetta 1.8 T
Old Apr 11, 2004 | 07:39 PM
Dan_Max2kBR's Avatar
Hey Guys.. I would like to get some answers here and I know you guys can help me... My friend got this 2001 jetta(Wolfsburg ed.) 1.8 turbo.He`s running I think 20 pounds of turbo in his car(I dont know if I did say right ) but he wants to race me ...I have a 2k1 Max 5spd, for mods only air intake? should I race him?any chance of winning?\\\ let me know please....
Old Apr 11, 2004 | 07:49 PM
schernov's Avatar
You are going to beat the he11 out of him
irish44j's Avatar
retired moderator
you're kidding, right? You should take him.
But just race him and find out. What's the worst that can happen, you lose?
in before the lock....the org doesn't encourage posting about street racing, by the way....so this thread will get locked fast.
Not a good post to make a first impression!
Old Apr 11, 2004 | 08:09 PM
1BADMAX's Avatar
If he's stock you should win, but if he's chipped then your screwed. Either way it'll be a good race.
Old Apr 11, 2004 | 08:17 PM
Well, He got the blow off valve on , running about 20 psi I think ,..I dont understand that if it is pounds or psi..also he go a cold air intake..What`s gonna be on 1/4?
Old Apr 11, 2004 | 08:18 PM
Shift_VQ's Avatar
20 pounds sounds like a lot of boost...definitly not stock i think he'll beat you...but do it anyways
Old Apr 11, 2004 | 08:20 PM
maxspeed96CT's Avatar
The original VQ...
in before lock ...you'll smoke um
GeSeKeE19-'s Avatar
WOW...20lbs of boost? Stock Turbo? If he is really runnin 20lbs of boost, im pretty sure ud lose. Can you even run 20lbs of boost without reinforcing your block??
Old Apr 11, 2004 | 08:23 PM
blue2k2's Avatar
psi = pounds per square inch
Old Apr 11, 2004 | 08:26 PM
Well as I said , I dont understand nothing about turbo.. but he got the stock turbo and he intall that blow off valve. his car is fast but I believe in my Max..227 Hp max against a 150 hp Jetta 1.8 T? I know turbo makes the diference but I will race him ... We never know until you get on the black top...
Old Apr 11, 2004 | 08:30 PM
Ferbs02SMMax's Avatar
When will the noobs learn? I don't know which is worse, this type of thread or what is the best intake threads?
He slides headfirst, and he's safe! In before the lock.
Old Apr 11, 2004 | 08:33 PM
Y2K1JKSE's Avatar
the 1.8T turbo is the equvalent of someone sneezing into the engine..the turbo is very small and i highly doubt that he can run 20psi of boost and not blow his turbo and/or engine...you should be able to beat him..but i suggest you take it to the track..that way when you do..you have a slip you can bug him with afterwards =)
Old Apr 11, 2004 | 08:43 PM
2k3TitaniumSe's Avatar
Don't race him. You're gonna lose big. A chipped 1.8T by APR makes them run the 1/4 mile at 14.19 at 99.79. A turbo at 20 psi is probably a stage 3 APR turbo kit meaning a lot more trouble. Trust me those 1.8Ts are quick. My cousin's 2001 1.8T is chipped and screams like a beast.
Old Apr 11, 2004 | 08:45 PM
No he has no stage 3 turbo..
Old Apr 11, 2004 | 08:51 PM
doublea's Avatar
I dont see how he can have 20 lbs of boost with stock internal ??? If he really got 20 lbs of boost he's going to spank you unless he's a very bad driver, but even though I would race him and see the result.
Good luck
AA
Old Apr 11, 2004 | 09:00 PM
K1maxima02's Avatar
It's possible to have 20 PSI boost for stock turbo. My firend has GTI 1.8T and he has very close to 20 PSI boost. Anyways, you will win but if he's chipped like APR tuning, your screwed. I seen stock 2002 GTI 1.8t only mods are APR CHIP. AND he ran 14.3's.
Old Apr 11, 2004 | 09:01 PM
Supreme Allah's Avatar
race him just to see his engine blow up ~
Old Apr 12, 2004 | 02:38 AM
Weimar Ben's Avatar
Helicopters! Money!!!
20 psi is a hellova lot of boost for a stock turbo with stock internals. There's no way you could get 20psi with a stock turbo and even if you could, it would blow the stock engine within minutes or even seconds. You prolly wouldn't be able to use pump gas either.
TallTom
57
Oct 14, 2025 05:16 PM
umnitza
Sep 1, 2015 01:03 PM
supercharged
Nov 28, 2000 08:47 AM
AntGVR4
Oct 10, 2000 11:29 AM
