Spark plugs...need some help
Old 04-21-2004, 03:33 PM
super6's Avatar
i got my maxima with 74k miles about a month ago. now i got 75k. i took out one of the spark plugs and it looked fine. but i dont think they were ever changed.
should i change them if they look ok? and which ones to get for 2000 maxima se?
will it run better if i will (i mean noticable difference)?
will it bad bad for the car if i dont change them?
and why im reluctent to do it is because the front 3 look simple, but i cant even see the back 3 plugs. is it as much of a pain to change the plugs on a 2000 as it looks?
super6 is offline
Old 04-21-2004, 03:34 PM
Y2K1JKSE's Avatar
i wonder the same thing...i want to change mine to some iridium ones but the back three i know are under the intake manifold and i'm wondering how long thats gonna take to get off..plus i'm iffy about the spacing of the plugs also...if anyone has a good how-to or whatnot that would be nice
Y2K1JKSE is offline
Old 04-21-2004, 03:35 PM
super6's Avatar
i meant be bad for the car
and where do i get new ones? thanx.
super6 is offline
Old 04-21-2004, 03:59 PM
CCx
CCx's Avatar
You can get a 6-pack of new ones from www.courtesyparts.com for about $60 - OEM replacements are fine, unless you've got a real reason for anything different.
It's a large pain in the ***** to change the rear ones. Your back/legs may hurt, but it's not that big of a deal....just don't drop anything back there, best to make sure you've got a magnetic rod available just in case
CCx is offline
Old 04-21-2004, 04:05 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
Well it is a pain but not as bad as the Lumina from 1994. you actually had to uncrewed the engine mounts.
Does anybody know where can I buy the iridium plugs? and for how $$$$
Lontar1 is offline
Old 04-21-2004, 04:34 PM
super6's Avatar
so do you actually have to take the intake manifold off, or anything off?
i cant even see them. i donno if u should try to do it myself or have nissan do it. theyll charge up the *** for anything.
has anyone actually did it themselfs on a 2000? and how do u do it (i mean get to them)?
super6 is offline
Old 04-21-2004, 04:38 PM
BigDogJonx's Avatar
Ive changed the plugs on mine about 4times now, its not that bad, takes about 1hr if you taking your time. The rear ones are not that bad. You dont have to take the manifold off. If anything may want to remove the bracket that holds the throttle and cruise cable near the TB. But all you need to do is remove the 10mm bolt that holds the coilpack down, for the rear use a magnetic rod to grab the bolt out. Then remove the coilpack and remove the plug.
Gap them at .044" for stock.
Dixit
BigDogJonx is offline
Old 04-21-2004, 05:30 PM
Mom's2kGLE's Avatar
You can get magnetic inserts for your sockets at Sears, this will aid in the rear plugs. Also be sure to use the dielectric grease on the spark plug boot.
Mom's2kGLE is offline
Mom's2kGLE's Avatar
Old 04-21-2004, 05:58 PM
super6's Avatar
ye i got the spark plug socket, what doe sthe degreaser do? do i have to use it?
super6 is offline
Old 04-22-2004, 03:22 AM
MrGone's Avatar
I replaced the ones in our 2000 SE 5spd with BKR5E-11's and it fixed a small studder the car developed at 3300 and 3600rpm.
MrGone is offline
Old 04-22-2004, 04:56 AM
jmh8's Avatar
I also have 70k on a 2000. The plugs have never been changed and the car runs great. Do I need to change them? If I do, what other routine maintenance should I do now with 70k. The car runs great.
jmh8 is offline
Old 04-22-2004, 11:44 AM
jmh8's Avatar
bzuuuuuuuuuump
jmh8 is offline
Old 04-22-2004, 11:51 AM
[maxi-overdose]'s Avatar
If it runs fine, I wouldnt change it.
If you want to see your engine's condition, just take out a plug and see if it is running rich or lean or having any oil on it.
What maintenance have you done before 70k?
[maxi-overdose] is offline
Old 04-22-2004, 11:55 AM
silicon electrical grease will keep water out and increase conductivity. I thought this is for cars with spark plug wires but not for us.....
Old 04-22-2004, 05:42 PM
VW = 30 MPG
DonGfun's Avatar
110,000 miles for my 1st change ... Gas milage went down for a while better now ... some plugs had a 84 gap when I took them out!!!!
don't run no different
DonGfun is offline
Old 04-23-2004, 04:35 AM
Mauja He Mauja
ZIPPIN's Avatar
i have changed them 6 times. takes about 1/2 an hour. there is a write-up in the how-2 section. be careful not to pull the rear coils by the connecting wires. always get them by the boot..
ZIPPIN is offline
Old 04-23-2004, 04:38 AM
Mauja He Mauja
ZIPPIN's Avatar
found it. here you go
ZIPPIN is offline
Old 04-23-2004, 06:38 AM
I hope you meant 0.084 inch of gap. You sure the car was running fine? the engine didnt miss or anything?
nissan recommended to have those plugs replaced at 70k IIRC. you already passed it for 40k, it doesnt surprised me that the plug gap got bigger.
Need help
23
10-02-2015 08:56 AM
Gingerheadman
10-01-2015 05:11 PM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
msellas
09-23-2015 09:16 PM
Quick Reply: Spark plugs...need some help
