Foglight's On w/ Highbeams **WRITE UP**
Yeah, removing the cover and knee area cover is pretty self explanitory.
However, a good WARNING/tip to include would be to disconnect the battery and wait 10-mins., since you're working VERY closely with the airbag wires.
Originally Posted by 2k2whitemaxi
hey guys i tried this and did it the way it said to....but the problem it during the day when the hids are off...and i flash teh high beams...my hids flash as well
now i have to go back and put it back to normal tomm
-J
-J
Dave
02 Maxima SE
85 El Camino w/Turbo V6 swap
Originally Posted by Triple8Sol
I just did this, and for some reason now my fogs are not working? I followed Igor's directions exactly for a 2002-2003. HELP!!
You don't need to remove the lower part. you can ground the wire by squishing it with any of the default plastic parts, as long as the bare wire makes solid contact with the metal part of the column. Just loosen a screw slightly, pull away a plastic clip or whatever, tuck the wire under it and tighten the screw back.
That's what i did since i couldn't find a decent grounding point on the 2k without removing all the plastic stuff off.
On another note, why is it illegal to have the fogs on with the high beam?
Originally Posted by dba1999us
igor,
what type of fogs are you running? how much, and where to get em?
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
