Oil Consumption?
Old May 16, 2004 | 02:52 PM
MaxSE2k's Avatar
Oil Consumption?
I've always been puzzled by the fact that when I do an oil change, I drain approximaty 3 quarts of oil, but put in 4.25 quarts. I really hope I'm not alone in this.
Do you bother to add oil? If so, how much have you been having to add & how frequently?
Old May 16, 2004 | 03:56 PM
ajahearn's Avatar
A 1.25 quarts seems high to me. I normally am down between 0.5 and 1.0 quart every 5K miles. How often do you change your oil? Its normal for a certain amount of oil to get past rings, etc. and get burned with your gas. Of course the issue is how much.
Also there was a posting awhile back where the guy recommended getting your used oil tested. He sure made a good case of how you could diagnose some problems from the used oil. Never tried it myself but you might look around.
Old May 16, 2004 | 05:20 PM
bigdo26's Avatar
Mine usually drains 4 quarts and i put in 4.25. I'd think 1.5 quarts of burned oil is quite high...
Old May 16, 2004 | 06:51 PM
irish44j's Avatar
retired moderator
I just drain it, and put in 4 quarts, then run the car, stop it, check the dipstick, and fill more if needed.....
Old May 16, 2004 | 07:04 PM
ZIPPIN's Avatar
Mauja He Mauja
i always put in 3.75 quarts...
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
