engine temp. (kind of high?)
Old Sep 23, 2000 | 11:29 PM
Hi,
I have noticed that the car heats up. Don't know if it is normal. I can even feel the heat coming during cool weather situations, after 10min of normal driving. (my legs heat up)
The temp. on the car gauge reads half way of the blue indicator.
When I stick my hand out while driving, I can feel the heat from the hood.
Can anybody confirm the situation
Normal/abnorma?
Thank you
Old Sep 24, 2000 | 03:00 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
My gauge never gets to the halfway mark. It's always (to the best of my knowledge) been underneath it be a few millimeters.
I can feel the heat coming from underneath my car when I open my door. I assume (and hope) this is normal...
Old Sep 24, 2000 | 03:43 AM
mingo's Avatar
oh no its' not
better have it checked out.. could be your cars are running lean.. heheeh nah it's normal, exhaust has heat, heat dissapates. and as far as your legs heating up. it's probably the vents letting air in. it's usually warm. happens when you don't leave the ac on recirculate before u turn it off. but your car does sound a bit abnormally hot.. not so sure tho.
Old Sep 24, 2000 | 06:30 AM
UMD_MaxSE's Avatar
Got Bent?
Get it checked out. Check your coolant level in the resevoir and the radiator also. I have never seen the temp gauge even come close to getting to halfway on mine.
Old Sep 24, 2000 | 11:18 AM
TimW's Avatar
The silent but deadly Moderator
I've run in 115 degree weather with
all acc. on in bumper to bumper traffic (and flat out) and my temp never went above midway (actually a hair below)
Old Sep 24, 2000 | 06:41 PM
mingo's Avatar
could this be it??
your thermostat is stuck half closed. if it was all closed your car would be well over the H mark patially closed somehwere below it but above normal
Maxima.KsA
May 15, 2020 04:14 PM
03VQMAX
Sep 5, 2015 03:47 PM
Maxboy23
Sep 4, 2015 06:04 PM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
