Flashing...the ECU that is; for a new MAF?
Old May 17, 2004 | 08:15 PM
Rich1's Avatar
I recently got the P0171 and P0174 - System running too lean bank 1 and 2 respectively on my 2000 Max SE. I called my Nissan service advisor and he mentioned that it's most likely the MAF and a ECU flash is required to update the ECU for the new MAF - I have also confirmed this from other postings on the org...
I'm ordering a new MAF (22680-2Y001) from Dave B. and going to install it but I was wondering:
1) If a ECU flash is really needed? People have installed the new MAF any ECU problems?
2) I have had O2 sensors and ignition coils replaced recently at the dealers (yeah..it cost a lot) at which time they "flashed and reset the ECU" for these new updated parts. Does anyone know if a ECU flash will update the ECU for all parts or only specific ones? I.e. Sorta like updating Windows on your computer - you get all the latest drivers. I'm hoping that the last ECU flash also loaded the info for the new MAF!
FYI: All the other Canadians out there - some dealers in the GTA are charging $600 CAN for the new MAF (22680-2Y001)
Old May 18, 2004 | 02:25 AM
Jime's Avatar
Well mine is a 2k2 which blew a MAF, I just installed the 2k1 MAF from Dave B and transferred the temp sensor.
Car runs like never before, much smoother idle etc with no flash etc. Not easy getting around with a 2400 RPM limit for 2 weeks.
Old May 18, 2004 | 06:58 AM
Raven's Avatar
Rich1, I too had the same problem as you, I was getting the P0171 (bank 1 too lean) error. I found this out when I went for emissions testing and failed! DOH! I have yet to replace the O2 sensors and the ignition coils, fyi.
The ECU required no upgrading, but I was told to wait a few weeks to let the codes clear out of the ECU before I took it back for testing. Keep us updated.
I replaced my MAF with that exact same part # and the problem instantly went away.
Old May 18, 2004 | 09:04 AM
nailz420's Avatar
My fuel economy went down after I replaced the MAF(22680-2Y001) at the dealership. Snap-on scanner revealed that my engine is running lean borderline to throwing a code. I ran scanned my car myself and it showed that second o2 sensor at idle sometimes goes to 0 and stays there for a while. So I am thinking, is it my o2 sensor or dealer "forgot" to flash the ecu after the MAF?
Btw, anyone have that MAF tsb? the old link in the stickies doesnt work.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
ballerchris510
Sep 10, 2015 09:35 PM
