Is this the drain plug?
Old May 18, 2004 | 08:32 PM
PTP's Avatar
PTP
Help, I want to do a MTF flush tommorow but I am not sure about the drain plug? Can somone check these pics and let me know.
Is this the drain plug? http://images.fotopic.net/?id=4551638&outx=600&oq=0 and http://images.fotopic.net/?id=4551641&outx=600&oq=0
This the the fill plug right? http://images.fotopic.net/?id=4551642&outx=600&oq=0 and http://images.fotopic.net/?id=4551637&outx=600&oq=0
This is the shift sensor right? http://images.fotopic.net/?id=4551643&outx=600&oq=0 and http://images.fotopic.net/?id=4551644&outx=600&oq=0
Thanks, I appreciate it.
Old May 18, 2004 | 08:50 PM
asu174's Avatar
Clay Aiken has fancy genitals
Drain plug- yes
Fill plug- yes
Shift sensor-I have no idea
Old May 18, 2004 | 11:49 PM
panda_1's Avatar
how hard is it to do the flush, and how many quarts of what fluid.<<<<<<<never done this before.
Old May 19, 2004 | 03:23 AM
ZIPPIN's Avatar
Mauja He Mauja
how about you look around the web-site in the how-2 section
here you go
Old May 19, 2004 | 06:11 AM
PTP's Avatar
PTP
here you go
Thanks but the '02-'03 are different from the '00.
Old May 19, 2004 | 06:15 AM
PTP's Avatar
PTP
I am going to try it today. Everyone says is pretty easy, supposedly if you can change your oil you can drail and fill your trany. Check out the Fluid section for all the details on how to change the MTF and what fluid.
Old May 20, 2004 | 11:00 AM
panda_1's Avatar
i changed my tranny fluid yesterday. i have a 2k 5-speed and it was very easy. it took approxamitely 5 quarts. what i did is i filled it until it started to overflow then i immediately put the filler plug back in. i used mobil 1 fully synthetic 75w90 fluid.
Old May 20, 2004 | 01:59 PM
PTP's Avatar
PTP
Just finished draining the MTF today and it was pretty easy. I used the shift sensor approach rather then the drain plug. When I started to take the drain plug out I was having problems. It wasnt turning then the bold started to round out so I stopped. The shift sensor is much easer to reach and the fluid flows out quickly. The oil that came out was dark and stained w/ a golden/yellowish color and smelled bad too. I replaced with Amsoil series 2000 and it seems to shift much smoother.
Is the Amsoil supposed to be greenish?
Old May 20, 2004 | 02:02 PM
PTP's Avatar
PTP
Life time of Amsoil.
Any one know anything about the change cycle of Amsoil Series 2000 MTF? The back of the bottle says it lasts the LIFE of the car and NEVER needs to be changed again?! Can this be true? I thought Nissan recommended every 60K-70K you change the MTF.
Old May 20, 2004 | 02:19 PM
Colonel's Avatar
Old Fuddy Duddy
Yes, AMSOil Synth Gear Lube is green.
As for the longevity of the gear lube, that is really up to you. Most people never change tranny fluid...auto OR manual. Some change it all the time (I have done it 3 times in 34K miles)....some fit in between.
Bill99gxe found that the OEM fluid in his auto wasnt worth a whooey after 18K, and had some similiar results with an Acura as well. Might want to check out the fluids forum for the DL'able spreadsheet and do some readin...might help your decision.
Forge277
Jun 13, 2016 09:26 PM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
