Fog light is out?
Old May 18, 2004 | 08:46 PM
Max2000SE's Avatar
Fog light is out?
I noticed tonight one of my fog lights is out. I looked in the manual and it says take it to the dealership. I know they will charge an arm and a leg, any thoughts on changing it? I know my dad had a similar problem with his lexus and only the dealership could change it..PLease help...???
Old May 18, 2004 | 09:04 PM
[maxi-overdose]'s Avatar
you can change it yourself. check out the how-to stickie and I believe there's a write-up.
if not, go to www.max-world.org and they have russ's write up over there.
Old May 18, 2004 | 09:21 PM
Max2000SE's Avatar
Yea I found the 02-03 write up, Still looking for 00'...Any clue what bulb is used on the fogs? Book doesnt say anything either.?
Old May 18, 2004 | 09:33 PM
Max2000SE's Avatar
Is either link working for you? I checked out the how/to and it will not open..And on the max-world site, it says error site cannot be found...Any luck getting the link if you could post it for me that would be great...thanks, ill keep on trying
Old May 18, 2004 | 10:21 PM
ch13f's Avatar
the bulb should be an h3.
Old May 18, 2004 | 11:09 PM
for some reasons, it is not on max-world.org anymore. anyways, 02-03 write up will work for replacing 00 fog light bulb IIRC.
Old May 19, 2004 | 01:32 PM
Max2000SE's Avatar
Thanks for the info guys...The 02-03 write up almost got the job done...INstead of there being 2 bolts holding in the light there is a little screw underneath the housing and 2 clips that didnt want to budge. After some pushing and prying it came loose. Not to mention the crappy screws underneatht the car that didnt want to be removed...But happy to say it worked out and all is fine......$14.90 later (ripoff for the bulb)
Old May 19, 2004 | 05:40 PM
SEdge
before you run out and buy new bulbs, you might wanna identify exactly where the problem is. might just be that the bulb is shot, or maybe just a blown fuse.
Old May 19, 2004 | 09:13 PM
Max2000SE's Avatar
I didnt really think that just one bulb could go out and it still be the fuse...I figured that if it was a fuse both would be out or others would too. I just replaced it, no big deal...
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
