power seats
Old Jun 2, 2004 | 02:44 AM
mt7288's Avatar
power seats
my 2000 se power seats will tilt but will not slide forward or back, any suggestions?
Old Jun 2, 2004 | 03:44 AM
UMD_MaxSE's Avatar
Got Bent?
mine too... drivers side will tilt forward and back fine and recline as well, but no forward or backward motion... I am thinking it's a fuse somewhere, but not in one of the fuse boxes... I need to look up how it is wired in the FSM...
Old Jun 2, 2004 | 04:54 AM
mt7288's Avatar
If you find anything please post because I can not figure it out !!! Thanks
Old Jun 2, 2004 | 06:24 AM
gtmassive74's Avatar
hey guys, i'm having a problem to set the seats on my 03 max, i don't have the manual. I know when i bought the car the salesman show me, but now it seems i can't set it. I try pressing the set button and #1, but no lights light up, can someone tell me how to do this.
thanks
gt
Old Jun 2, 2004 | 06:30 AM
Woo Cho's Avatar
I had exactly same problem on my driverside power seat except mine did move forward and backward and didn't recline(tilt). I recently got fixed through dealer it wasn't anything big they said it's just the **** is broken. I had extended warrenty so dealer fixed under warrenty, dealer just replaced the little plastic **** on the side of the seat.
Old Jun 2, 2004 | 06:36 AM
ajahearn's Avatar
03 seat problem
thanks
gt
Your problem is different than the original poster. To activate the seat memory hold the set button down till it lights up then press either 1 or 2. To use either memory 1 or 2 you need to have the car in park (I have an MT and for that you have to have the parking brake on).
For the guys with the seat motor problem, my 02 ESM doesn't show a separate fuses for the recline and forward/backward. Sounds more like you have either a switch problem or a motor problem. Hope this helps.
Old Jun 2, 2004 | 06:51 AM
mt7288's Avatar
crazy thing is that both the drivers and passenger seats are tilting but not sliding so I doubt it is the motor or the switch because the odds of both of them going out at the same time must be extremely slim.
Old Jun 2, 2004 | 06:56 AM
maseo77's Avatar
my seat wont raise or lower???
Old Jun 2, 2004 | 07:04 AM
goldmaxNYC's Avatar
There is a TSB for drivers side power seat tilting but not slding back/forth.
Old Jun 3, 2004 | 02:48 AM
mt7288's Avatar
have you been able to find anything?
Old Jun 3, 2004 | 04:00 AM
UMD_MaxSE's Avatar
Got Bent?
not yet... I've had no time... I was at work real late yesterday...
Old Jun 3, 2004 | 06:08 AM
ajahearn's Avatar
This does sound more like the TSB issue.
http://maxima.theowensfamily.com/tsb/NTB02-001c.pdf
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
zmcneely13
Sep 26, 2015 02:26 PM
Bluenissan
Sep 20, 2015 08:54 PM
