Need Help..2000 Max stalling in idle (Manual)
Old Jun 10, 2004 | 08:21 PM
jport4087's Avatar
I need some help. My car has recently been stalling when coasting in idle. It is a 5sp manual. It happens once or twice a day but I am tired of feeling like a tool that can't drive a stick.
For example: If I am pulling into a red light and put the car in neutral..it will sometimes stall. Other than that the car runs good. If I downshift as I am slowing down ...then the car will be fine. It almost seems like it runs out of gas or the idle is set too low. Like I said, it doesn't always happen but its getting to the point where it is affecting my driving. I sometimes coast into an intersection and make the quick right as I scan for traffic..I would hate to jump into traffic and have it stall right in the path of upcoming traffic.
Any suggestions? Is it related to the fuel-cut issue or the crappy MAFs?
Junior
Old Jun 10, 2004 | 09:10 PM
ToYLeT902's Avatar
JET Speed Lab
maybe the MAF is bad, same thing happened to me plus my idle was very jumpy.
Old Jun 10, 2004 | 09:16 PM
davecmu's Avatar
Clean your throttle body. The butterfly valve inside the throttle body becomes gummed up with carbon and stuff every 30,000km, and you'll need to go in there and clean it out until it's nice again.
Cost: $2.99 for TB cleaner and some rags from home.
If that doesn't work, then look at other things, but that should clear it up.
Old Jun 10, 2004 | 10:24 PM
E-dUB's Avatar
i had this problem in my '00 max too. i changed my MAF and it was all good after that. if it isn't the MAF then clean out your throttle bottle like davecmu said.
Old Jun 11, 2004 | 02:01 AM
jhilsman's Avatar
Definetly clean your throttle body...
Old Jun 11, 2004 | 08:44 AM
paralyse's Avatar
I Miss My Maxima
Fuel cut TSB has same symptoms, and applies to manuals only.
Old May 4, 2007 | 07:20 PM
big h's Avatar
I just got clutch (OEM Exedy) replaced and everytime I downshift from 2nd to neutral (say coming to a red light), the RPM dips below the 500 rpm but pops back up to normal...feels like its about to stall, but RPM slides back up to around 750RPM...could this be MAF sensor? or something wrong with the clutch?
Old May 4, 2007 | 09:16 PM
MaxBoost925's Avatar
Drug Money
It would be the MAF.
Upgrade MAF, /thread.
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
Vequity
Sep 10, 2015 05:26 AM
minsbang
Sep 5, 2015 05:36 AM
