warped rotors on 2K only?
Old 06-13-2004, 10:06 AM
dozu's Avatar
Is the rotor warping problem specific to 2K only?
I have a 2K1 SE 5sp. The steering wheel shakes a little during braking at high speed.... not sure if it's the rotor or something to do with alignment.
Thanks,
Don.
dozu is offline
Old 06-13-2004, 10:14 AM
TheyCallMeSteel
Screw that. My rotors warped on my 2002 I35 with only 25k on the clock. I fought with infiniti for ages and they wouldnt do ****. Held to "normal wear and tear," even after admiting that they shouldnt have gone that soon. What a ****ing joke! I told them that my peice of crap Grand Cherokee 5.9 lasted twice as long and that think was a track queen, and if infiniti/nissan products are that ****ty I wont buy again. They, of course, didnt give a flying ****.
Old 06-13-2004, 12:54 PM
ru4real's Avatar
No, warped rotors can occur on later model years also. I got warped rotors after owning my 2001 for one year. I found a dealer that would honor the brake judder TSB and cover it under warranty. Since then, I've been careful to torque my lugnuts evenly to spec., and I haven't had the problem again.
ru4real is offline
Old 06-13-2004, 02:47 PM
dozu's Avatar
that's good to know, maybe next week I will take it in for a check..... Alignment does play a major role though. I used to have a 1990 240SX (loved that car), it shook big time during braking at high speed, the car didnt pull to side but during annual inspection they told me alignment was bad, had it done and the warping was reduced by 80%.
dozu is offline
Old 06-13-2004, 04:50 PM
NJ Devils Fan's Avatar
Mine shakes when braking at high speeds also. People told me too that my rotors were warped. Its a 2002. I want to find my nearest nissan service center and see if they will replace my mats and change the rotors for free since it is still under warrenty.
NJ Devils Fan is offline
Old 06-14-2004, 02:45 AM
wild willy's Avatar
My car goes to nissan today for the 2nd time in 11k miles..If those fools cut them again I will be very upset....My 3 years are up in Oct.
What's the deal with Nissan rotors on the max & alti?
wild willy is offline
Old 06-14-2004, 05:06 AM
SkoorbMax's Avatar
"not sure if it's the rotor or something to do with alignment. " Almost certainly rotor. Mine were doing it on my 2k. Braking from highway speeds I'd get increasingly bad stuttering. After much soul-searching I decided to not buy new rotors, but just resurface the old for 1/3 the price. So far at 3k milse they're still good, though I have no idea how long they'll last. I would not buy OEM rotors though - go with brembo blanks or something.
Also for pads I went with $42 performance friction pads from autozone and them and the resurfaced rotors have so far been good.
SkoorbMax is offline
Old 06-30-2004, 04:28 PM
KWAK's Avatar
I have a 2K, with 56K mile on it. Front rotors warp badly, and resurfacing will not cure the problem. I have had the rotors turned 3 times, only to have the judder return after about 6K miles.
I tried Stillen cross drilled rotors, but did not stay with them because they generated a real irritating whinning when stopping, even after driving for 200 - 300 miles.
I'm looking for something else
KWAK is offline
Old 06-30-2004, 04:49 PM
retired moderator
irish44j's Avatar
Yes, they warp on the 2k1 as well.....The problem is that our rotors are undersized for how heavy the maxima is....nissan engineers apparently not very intelligent (except for those that designed the mighty VQ, of course)
For those of you with 17" or larger rims (including the stock SE rims), here is the solution:
http://www.mattblehm.com/relocation_kit.html
This is what I have...smooth as butter, not too expensive....no more brake judder/vibration/warping
compare in this pic our OEM rotors with the 2004 maxima rotors this kit allows you to use:
irish44j is offline
Old 06-30-2004, 05:30 PM
scopium
man my rotors warp faster than my pads...
i'm getting a BBK ASAP..
Old 07-01-2004, 02:47 PM
Grey00lustre's Avatar
hey guys i'm getting my front rotors replace with brembo blanks next weeks...i'm pairing them with stock pads...would this get rid of the vibration and brake judder when i brake during high speeds?
Grey00lustre is offline
Old 07-01-2004, 02:55 PM
imported_JIC_A33
blemco is the way to go. I will do the bigger rotors with better pads. everyone seems to like that setup as well..
Old 07-01-2004, 03:31 PM
ZAJOBA's Avatar
no diference for me if its OEM or Brembo blanks. 10-15k miles and its starts to shake really bad and needs resurfacing. Tried OEM and Quet Stop pads (dont remember the maker)..
They are too small for our big maximas..
ZAJOBA is offline
Old 07-01-2004, 05:59 PM
aussie983's Avatar
Yes it will. And make sure you hand torque the lug nuts.
aussie983 is offline
Old 07-01-2004, 06:10 PM
GimmeTorq's Avatar
Good luck... I've visit my dealer twice (at 15k and at 21k) and both times they just resurfaced them. Now, at 25k, the brakes are pulsating once again. I think I'm giving up and going aftermarket...
GimmeTorq is offline
Old 07-01-2004, 08:36 PM
2MAX's Avatar
You won't believe this... but I said the same to my Nissan dealer. Except it was concerning the exhaust system which went out after 4.5 years only. I just replaced it 2 days ago (no choice because of the noise). I got many cars previously and the exhaust lasted much longer than that. I bought a '92 Taurus LX brand new that I still own and I never replaced the exhaust (I stiil own the car!)
By the way, I know the Taurus is not the same quality... or is it?
2MAX is offline
Old 07-01-2004, 11:17 PM
panda_1's Avatar
my rotors have been warped on my 2k SE 5-speed. time for an upgrade.
panda_1 is offline
Old 07-02-2004, 04:22 AM
wild willy's Avatar
The rotors on my 02 Altima warped 2 X in under 11K miles.
Nissan really sucks..They cut them 2 X and installed the same old brakes 2 X.
I will be certain to warp these...They owe me new rotors
Old 07-02-2004, 05:40 AM
emhc1999's Avatar
Probably one of the most annoying aspects of owning a maxima. After you fix it, before you know it you feel slight virbrations then anger to follow shortly.
emhc1999 is offline
Old 07-02-2004, 11:59 AM
2MAX's Avatar
Overall though, the Max is a very good car. The chassis is rigid, driving is very safe and luxury is acceptable (I am talking about a 2000 car).
My brother-in-law owns a 2004 Accord fully-equipped (leather, NAVI. bla,bla,bla).
Very nice car... except I told him that it was not in the same class than the Max (5 years older). He agreed... (we are more talking about the Acura TL)
2MAX is offline
Old 07-06-2004, 11:31 AM
00Max00's Avatar
What's the wheel nut tightening torque for our car?
00Max00 is offline
Old 07-06-2004, 03:42 PM
retired moderator
irish44j's Avatar
guys just get either a true BBK (if you want to drop a couple grand) or get the BlehmCo kit (if you want to spend a couple hundred). Both of these will eliminate the warping rotors. Period. ANY brand of aftermarket rotors that are the OEM size (10.6" i think) are going to warp eventually. They are simply too small for the weight of the car...you gotta go bigger (12" 2k4 rotors or 12+" BBK rotors) if you want to be sure...Nissan is NOT going to solve this problem or do anything to fix it for you, so just give it up!
irish44j is offline
Old 07-06-2004, 05:55 PM
aussie983's Avatar
i think 70-80 or thereabouts if i recall correctly.
Old 07-06-2004, 06:00 PM
retired moderator
irish44j's Avatar
I personally hand-torqued the lugs to spec the last 2 times my buddy got his maxima rotors turned for warpage....so I know they were dead-on. guess, what, his warped a third time in under 3 months.
i don't recall the spec off the top of my head, but I looked it up at the time in the shop manual...I'll check in a little while if I get the chance and will post torque ratings here...
irish44j is offline
Old 07-06-2004, 06:08 PM
husker_max's Avatar
Ok so if I have a stock 2001 GLE what is my best option for a bigger rotor? I have 46k on it and they are warped bad. Will those from Matt Blehm fit a stock 2k1 GLE?
If not what are my other options?
DC
husker_max is offline
Old 07-06-2004, 06:16 PM
retired moderator
irish44j's Avatar
the blehm kit will fit if you have the OEM 17" rims, but not if you have the 16", unfortunately. If you have the 16" rims, you really have no BBK option at all...
irish44j is offline
Old 07-06-2004, 07:00 PM
Bl_asd's Avatar
I have 2000 GXE ( worst maxima ) My rims are 16". If I need BBk, I have to change my rims as well then? Can I change to 2004 12" rotors for a 16"rims?
Bl_asd is offline
Old 07-06-2004, 07:04 PM
retired moderator
irish44j's Avatar
no, the 2004 rotors with the BlehmCo kit will not fit inside the 16" rims...they just barely clear the OEM 17's as you can see here:
irish44j is offline
Old 07-06-2004, 09:43 PM
Alicia's Avatar
Funny. I was going to post a thread asking why my Max shakes when breaking from a high speed.
I got a scare on the interstate when I was doing 75 mph and some idiot pulled over on me. The steering wheel shakes so hard that it's almost hard to control.
I'm still under warrentee @ 55000 but looks like you guys are saying that the problem really can't be fixed permenantly.
Alicia is offline
Old 07-06-2004, 11:18 PM
Flip94ta's Avatar
I assume that the 12.6's use the 5th gen calipers and pads? Are there any plans to upgrade to 6th gen calipers?
Flip94ta is offline
Old 07-07-2004, 04:18 AM
schernov's Avatar
[QUOTE=irish44j]Yes, they warp on the 2k1 as well.....The problem is that our rotors are undersized for how heavy the maxima is....nissan engineers apparently not very intelligent (except for those that designed the mighty VQ, of course)
Irish, how many miles do you have on Matt's kit? What pads did you go with? Any issues so far? With stock 17'' by how much does it clear? In the winter, if all kinds of ice and snow get stuck there ... wondering if there would be any problems?
Thanks!
schernov is offline
Old 07-07-2004, 06:11 AM
Bl_asd's Avatar
[/IMG]
How if I change my 16" rims to 18"? will 2004 rotors fit?
Bl_asd is offline
Old 07-07-2004, 09:33 AM
00Max00's Avatar
Tell those !d!ots in the garages stop OVERTIGHTENING your wheel nuts. Keep away from those garages who are using compact wrenches.
00Max00 is offline
Old 07-07-2004, 01:41 PM
retired moderator
irish44j's Avatar
schernov - I probably have about 7-10K on them by now, but not really sure, might be a little less. I do drive hard in alot of heavy traffic on the DC beltway daily, so they get ALOT of use...
I use some basic cheap OEM replacement pads form the local auto store...Bendix
Clearance is maybe an inch....I'm not concerned about snow and ice, I didn't get any last winter stuck in the rims, the OEM 17's don't hold snow much..
Bl_asd: yes, they will
Flip94: no, I have no reason to upgrade the calipers. The OEM ones fit fine and getting new ones would add $$$ to the kit, no doubt. Matt also sells a kit that uses 300ZX calipers (which are larger) but you need to have 18" rims to fit those in there....
00Max....I really don't think lug torque is the major factor....read my post above about my buddy's max...that's a nice theory, but the fact is that our rotors are too damn small no matter how you look at it....
whew! out of breath now....
irish44j is offline
Old 07-08-2004, 05:11 AM
wild willy's Avatar
Lug nut torque is a factor....But...Nissan has crappy rotors no matter what the tq is
By the way..What is a Compact wrench? lolol Does it go in your purse?
Old 07-08-2004, 08:12 AM
00Max00's Avatar
I think I mean impact wrench lol
00Max00 is offline
Old 10-07-2004, 08:17 AM
SpottyJ's Avatar
Anyone have luck with dealers repairing front brake shuddering on 2002 Maxima's? I went to a local shop and they stated I need new pads and rotors ($400). But, they said there is a TSB out for my car and that I should bring to dealer. The TSB # the local shop gave me was NTB-00-033A. Searching that TSB number I can't find anything.
I have 25,000 miles on my 2002 SE.
Your input on what dealers have done for you, and if you have seen this TSB is appreciated.
SpottyJ is offline
Old 10-07-2004, 04:24 PM
aussie983's Avatar
You definitely have a case. They will probalbly try and screw u though, by saying only covered for 12k miles and say its a wear and tear item. Thats what happened to me....
I went and got brembo blanks and MM pads instead.
U should be able to find the TSB here:
http://maxima.theowensfamily.com/
but it seems to be down for now...
04-16-2020 05:15 AM
BkGreen97
04-02-2016 05:47 AM
Socalstillen
09-26-2015 12:01 PM
beerman1378
09-08-2015 02:19 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: warped rotors on 2K only?
