suspension noise
Old Jun 18, 2004 | 12:11 AM
azmaxipad's Avatar
suspension noise
hey guys I just lowered my girlfriend's 01 i30 w/ h and r lowering springs and now when she turns the car hard to the left it makes a popping/clunking noise. any suggestion as to what this noise is. everything is tight and properly installed on the vehicle. PLEASE HELP...
Old Jun 18, 2004 | 01:49 AM
GeSeKeE19-'s Avatar
I have the same problem with my progress drop with kyb shocks....my front wheel well makes that noise...if u look in ur wheel well while someone is turning the wheel, u will see that the shock is not turning properly, but it has friction....dont know how to solve that though...i jus know what the problem is.
Old Jun 18, 2004 | 02:21 AM
MaximaGirl97's Avatar
it sounds like a annoying loud popping noise on the left hand side, and it vibrates my steering wheel! I hate it!
Old Jun 18, 2004 | 03:11 AM
Chinkzilla's Avatar
your spring is not seated correctly on the strut, jack up your car, rotate your spring until it slides into the little 'notch'. that should take care of it
Old Jun 18, 2004 | 08:17 AM
meanbean's Avatar
The popping sound from turning is being caused by a bad strut bearing. You are recommended to replace that part on all new suspension installs. Part should be about $24-35 at your local dealer. If you don't want to replace it, just take it apart and put some bearing greese in there again. Keep in mind that this maybe a temp fix so your better off buying a new one since it doesnt cost that much and taking apart/reassembly of the suspension is a pain. Good luck.
Old Jun 18, 2004 | 09:00 AM
azmaxipad's Avatar
can i adjust it while it's on the car jacked up in the air?
Old Jun 18, 2004 | 09:09 AM
ZIPPIN's Avatar
Mauja He Mauja
where does the strut bearing go? i hear a popping noise from the left front as well..
Old Jun 18, 2004 | 10:51 AM
meanbean's Avatar
No. The bearing is being compressed so the strut/spring must be disassembled to get access to the bearing.
It goes between the mount and bracket. The black part of the bearing should be faced down. This will allow the strut to rotate freely.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
