Someone tell me wheres closest Power Wire(12v) from trunk I can use?
Originally Posted by paralyse
Why not use the latch ckt for the auto trunk release? It HAS to have a constant +12V so the remote and button inside the driver's door will operate it.
Originally Posted by ihavea5spd
tail lamp switch.
Originally Posted by MiniRX7
What are you running off of it?
Originally Posted by Xplayboy69x
the closet one is the tail lamp but it will only work when you turn your lights on, let me know if you find something
damn....there goes trying that
Originally Posted by aussie983
time to get out the multimeter?
Originally Posted by ChromeSE5
12volt power supply in either the rear seats or the one in the shifter console are the only ones i found.
Originally Posted by Igor911
Im pretty sure the tail light has a constant 12v+...some1 needs to test the wires.
Originally Posted by maseo77
I think you may be trying to figure out how to install the keyhole camera like I am. ?? because I have this question also
..... u havent wired it either?
Originally Posted by OpTi
why can't you use your remote turn on?
i havent read on this....but dont want to short it some how & this wire goes directly to my h/u which cost me a pretty penny
as long as the camera is grounded you shouldnt short out your head unit
Originally Posted by cobymoby
rear cig lighter would be easiest to find. the tail lamp, sub, rear trunk release all wold not have a 12V ignition on them.
Actually, come to think of it, it would be easier to route from the front 12v. You have to dissassemble the whole console just to get to the back of it. For the front, you have to just pop of the shifter console. The wiring willk be the same cause i dont think you want to dig up your carpet.
the camera mounts in the trunk keyhole and the power which comes from it is roughly 1 1/2 feet long, and theres a Video plug. why would you run the short power wire from the trunk to the front console??? the video wire yes but the power wire no.
because that is pretty much the only available 12v. Are we on the same page? I thought he asked about a 12v constant. All you have to do is splice a wire and there you go... a longer power wire.
Originally Posted by zooma
there is a constant 12v source in the latch for the trunk it is for the light switch of the trunk light. just tap into the wire before the switch. i am using that to power the memory of my sat tuner.
exactly where is this wire?
thanks
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
rbaker100
Sep 6, 2015 02:46 PM
