'02 Fog Light alternatives
Old Jul 5, 2004 | 08:13 PM
WildWillis's Avatar
I just pulled the fog lights out of my 2002 Max because they were both cracked. From looking back at other threads it seems like I'm not the only one with this problem. I've seem some suggestions on where to get good prices on a new OEM pair, but I was wondering if anyone has suggestions of other fogs that might fit well. I saw some remakes of the 00-01 fogs on ebay a few weeks ago which I liked a lot (more "euro-style" than the '02 fogs) but I called the parts department at my dealership and they said they were different. Anyway any suggestions would be apreciated. Thanks!
Old Jul 6, 2004 | 05:25 PM
WildWillis's Avatar
Anyone? Don't want this to go too many pages back!
Old Jul 6, 2004 | 09:12 PM
ryanel's Avatar
I have the exact same problem but have not seen anything that looks original and cheap. I have seen some round angel eyes fog lights that looked pretty good. Didn't get too far on it though and I actually didn't write down the website either. If you are interested in something not stock search around and see what you think.
Let me know what you decide, this is one of my next jobs.
Ryan
Old Jul 7, 2004 | 05:24 AM
2k3TitaniumSe's Avatar
Try Hella or go OEM. Nothing's better than OEM for fogs.
Old Jul 7, 2004 | 05:40 AM
MiniRX7's Avatar
Alternative for my 2k3 fogs.
Click page 8
http://www.cardomain.com/id/minirx07
Old Jul 7, 2004 | 07:24 AM
black-maxim's Avatar
Originally Posted by MiniRX7
Now we begin the installation process. I decided to remove the front bumper, as it was MUCH easier to install these and screw them in.
how hard is the installation would be if your not removing the bumper?
i was planning to buy these foglights but im not interrested in removing the bumper...
Old Jul 7, 2004 | 07:49 AM
Click page 8
That looks great. Nice alternative.
Old Jul 7, 2004 | 11:33 AM
MiniRX7's Avatar
I removed the bumper because it was very simple to do so, plus i wanted to get at the wires on the side markers.
I doubt it will be easier by NOT removing the bumper because, i mounted the fogs by screwing it in to the back wall instead of below or above.. therefore the bracket is 180degrees out. REASON? well that why the lights sits right in the center of the hole.
Plus i rewirde my car as stated on my cardomain page via the left corner light and factory fog lights + 2 relays. so i can retain the factory fog light switch.
Old Jul 7, 2004 | 12:47 PM
UGAd13's Avatar
MiniRX7 - Please leave your car how it looks right now b/c it was frickin' ugly before. It's looking good now. BTW, what up with the RX7 thing???
Old Jul 7, 2004 | 02:01 PM
MiniRX7's Avatar
Really? i really really loved my sarona kit except for the fit and the stupid fiberglass crap.
Old Jul 7, 2004 | 03:48 PM
MaximaPolak's Avatar
I have OEMs and they have never cracked yet.....
mmm...Polargs....and OEM fogs still not cracked....
Old Jul 7, 2004 | 05:39 PM
Damn, you're a ricer! jk
Old Jul 7, 2004 | 06:42 PM
WildWillis's Avatar
Hey thanks for the suggestions everyone. I think I'll give those angel eyes a try. They look good on MiniRX7's car. Can't you pick those lights up at like Pep Boys or something? MiniRX7, if you could give a little more details on that wiring scheme or how you took off the bumper that would be great. Thanks for all the info and suggestions everyone.
Old Jul 7, 2004 | 07:04 PM
MiniRX7's Avatar
BUMPER REMOVAL:
There are screws under neath the car, you can't miss them. Just unscrew everything attached to the bumper from underneath.
Now, there are screws in the wheel well, you can't miss them, it may be covered by the black shield.. You ahve to pull it back, its flexiable so dont be affraid to use some force.
Now at the top of the grill, there are those little black tabby things, just pop them out with a flat head.
I recommend you remove your side markers and unplug them)..
Now you can slide the bumper off.. unplug the OE fogs and your fogs are completely free.
FOGLIGHT WIRING:
THere are 3 wires that come off each foglight. A negative ground, a + for the lights, and a + for the angel eyes.
THey supply you with a switch. Just throw it away.
Let me outline what i did in terms of operations:
You retain your OEM foglight switch and this is how it functions.
When your headlights are on, and your foglight switch is off, your angel eyes will be on.
If your headlights are on and your fog light switch is ON, then your angel eyes are OFF and your foglights will be on.
What you need is TWO RELAYS.
I won't go into the actual diagrams but here is what i did.
YOu need to wire the the first relay to the + of the battery, and then to tjhe 2nd relay. Now HOOK UP the + from the clear markerlight to the relay and then ground the relay. In this relay, you really only need a 4 wire relay.
WHat this relay does, is when your parking lights are on, it turns on the power to the 2nd relay with full battery voltage.
Now for the 2nd relay, tap the + from the factory foglights. For this relay you need a 5 wire relay. Now connect the relay to ( i cant remember the numbers on a relay) but to the foglights directly (this wire is the one that turns on when the relay sees the + from the OEM fogs). The other wire connects to the angel eyes (which turns on when the relay does not see the + from the OEM fogs). Now ground the relay.
Tape everything up, and there you go.
SUMMARY:
RELAY 1 connects to:
1. Ground
2. + battery
3. + side markerlights
4. Input + to the 2nd relay
RELAY 2 connects to:
1. + from relay 1
2. Feed + to foglights
3. Feed + to angel eyes
4. Input + from facotry foglights wire
5. Ground.
I hope that helps, it would have been nice if i remember the numbers on the pins of the relays but i dont.
In essence, the wiring will take under 30minutes to do, but what you end up with is the usage of the FACTORY FOG SWITCH which in turn also turns off AUTOMATICALLY with your auto headlights. Simplification, clean install. WORTH EVERY MINUTE.
ED
Old Jul 8, 2004 | 02:59 PM
WildWillis's Avatar
Hey thanks a lot for the detailed post. I'm going to go see if I can pick up a set of the lights at pep boys right now. Hopefully it'll stop raining so I can give this a shot tonight. I'll let you know how it goes. Thanks again for all the details.
Old Jul 8, 2004 | 03:50 PM
bigdo26's Avatar
check my homepage as well for ideas. the ones i have match almost 100% with the HID's. More light output than stock fogs too
Old Jul 10, 2004 | 10:14 AM
Audtatious's Avatar
Bandwagon Lover
Both of mine were trashed (cracks and holes). Dealer and online wanted between $150-$165 for EACH replacement. So, I ordered the GXE foglight kit from nissanwholesaleparts.com for $133. Included both fogs, wiring and even the blinker-stalk. These are factory fogs with nissan logo's on the glass. Great deal if you ask me
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
