Starter or Battery?
Old Jul 5, 2004 | 11:08 PM
00MAXI's Avatar
Starter or Battery?
My car stalls on startup. In addition, when the car doesn't stall it acts like it's going to stall then something seems to grab it from not stalling and the rpms bounce back up to 500-800. Weird ****! Sometimes I have to hit the gas to get keep from stalling.
Old Jul 6, 2004 | 12:45 AM
CJ7's Avatar
CJ7
If your started was bad then it wouldn't start at all. If it starts then it's not your battery because it's needed to turn over the starter. If your battery was so weak as to not turn over your starter you would know it.
It could be anything. On my old car if it sat over night it wouldn't start in the morning because of a bad temp senser telling it that the engine was allready warm. Is it showing any codes?
Old Jul 6, 2004 | 12:58 AM
nyautostyle's Avatar
umm
Sounds like its your alternator, I would have it checked along with the battery.
Old Jul 6, 2004 | 05:53 AM
Progress's Avatar
It's business time.
Idle control problem?
Old Jul 6, 2004 | 08:22 AM
00MAXI's Avatar
You are right it can't be the starter or the battery. Hmmm I have no idea. Spark plugs, coils, pcv valve, and MAF are all new. I even did a fuel induction flush. I may need to clean my K&N panel filter.
Old Jul 6, 2004 | 08:26 AM
MaximaPolak's Avatar
Maybe the plugs are not tight enough or not spaced right.
Old Jul 6, 2004 | 12:40 PM
00MAXI's Avatar
That's a possibility however a nissan tech installed those along with the coils at 84k when the the coils went out. I know not all techs are good but the damn stock plats are pre-gapped from the factory.
Old Jul 6, 2004 | 01:54 PM
paralyse's Avatar
I Miss My Maxima
New doesn't necessarily mean good.
Setting any codes?
You SURE all 6 new coils are good?
You SURE the new MAF is good?
Other things to check..hmm..idle air bypass..possible leak (vacuum or gasket) on the intake side of the MAF, letting unmetered air get into the engine...an accessory (ac compressor, alternator) locking up and putting too much load on the engine..
take it back to the tech and make them eat it.
Old Jul 6, 2004 | 02:46 PM
00MAXI's Avatar
No codes. The MAF is the new updated version. Vaccumm leak haven't thought of that I'll check that out. Maybe the tech didn't fasten the hose properly during the PCV Valve installation.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 30, 2015 03:32 PM
