ECU Reset for a 2k Maxima
Old Jul 22, 2004 | 12:50 PM
RichP23's Avatar
I found instructions on how to Reset a Max for a 2002+:
http://maxima.theowensfamily.com/ecu.asp
But will this work for the 2000?
If not, how do I reset the ECU?
Thanks.
Old Jul 22, 2004 | 12:57 PM
UMD_MaxSE's Avatar
Got Bent?
no.
The only 100% sure way to reset the thing is with a OBD scanner... overnight battery unplug may or may not work.
Old Jul 22, 2004 | 12:59 PM
scopium
i had to reset my ecu.. so i unplugged the battery for about 9 hours..
after reconnecting it.. we checked it with a OBD scanner and the code was completely erased.. it wasnt even pending.. is was out of the system..
Old Jul 22, 2004 | 01:32 PM
RichP23's Avatar
If I bring it to Autozone and have them pull the code (My SES light is on), will they be able to reset the ECU?
Old Jul 22, 2004 | 01:37 PM
SoonerFan's Avatar
Cletus
you shouldnt reset the ECU to get rid of a code. it is there for a reason and you need to use the scanner to see what it is.
resetting the ECU is good, but not for this.
yes, if you go to autozone they can check the code and then remove it. just make sure you fix the problem
scutmud
Aug 16, 2018 10:56 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
maximaham
Aug 7, 2015 01:11 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
