Looking for a bright white bulb
Old Jul 26, 2004 | 09:06 PM
al7601's Avatar
I'm looking for opinions in who makes a brighter white bulb. Is it PIAA or Polarg. ANy help and feedback is much appreciated. Please. Thank You
Old Jul 26, 2004 | 09:11 PM
scopium
brighter or whiter?
if u want whiter then PIAA
brigther then Sylverstar imo is the brightest
Old Jul 26, 2004 | 09:15 PM
steaLthyMax's Avatar
It would also help if you put what bulb you were looking to replace..headlight? dome light? courtesty light?
Old Jul 26, 2004 | 09:27 PM
al7601's Avatar
I'm looking to replace front blinker, and front sidemarkers.
Old Jul 27, 2004 | 05:23 AM
Kruppa's Avatar
I did Polarg and like the look...if you want the most bright and the most white get LEDs they have some for both of the lights you're looking to replace I think in 9 LED... www.superbrightleds.com or www.autolumination.com I have heard however that with LED's when you use the blinker that they blink twice as fast as normal..actually here is what superbrightleds says . . ."LED bulbs may cause some newer vehicles to indicate a bulb is burnt out (because of their low power consumption). Some cars indicate this by increasing the flash rate of the turn signals, some do not flash at all. This can be remedied with load resistors wired across the turn signal bulbs to simulate a filament bulb load. We have these available by our LED turn signal bulbs in our online shopping cart."
[note] my Polargs are not that bright as you can see in the picture however you can rewire them to make them run constantly at the same brightness as they are when you turn on the blinker (which is real white and bright)
Old Jul 27, 2004 | 05:25 AM
Kruppa's Avatar
In case you dind't know front blinker is 1157 and front sidemarker is 194 . . . http://www.win.net/audtatious/audio/...bulbchart.html
Old Jul 27, 2004 | 08:10 AM
al7601's Avatar
thanks for all the feedback Kruppa. I already bought the white LED's from autolumination with the load equalizers. Their white is actually quite purpelish and I have my sidemarkers rewired to flash with the blinkers and LED's in the sidemarker don't flash during the day. So I think I'll go back to the xtreme white PIAA's or go with the Polarg's. I am very interested in the rewire to make them run constantly as if they are flashing. If any one has directions that would be great. THANKS
Old Jul 27, 2004 | 08:24 AM
Kruppa's Avatar
check your PM
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
BobTX10
Oct 7, 2015 08:43 AM
Noela
Sep 26, 2015 08:22 AM
