problems regarding blehmco 5th gen reloc upgrade.
Old Jul 30, 2004 | 09:05 PM
panda_1's Avatar
problem regarding my blehmco 5th gen reloc upgrade.
i installed them and then went for a test drive, both sides are grinding beyond comprehension, i have pictures need someone to host them, they will be on my cardomain page. http://members.cardomain.com/30585
Old Jul 30, 2004 | 09:06 PM
panda_1's Avatar
im uploading the pics to car domain now, please gimme your 2 cents on the problem.
Old Jul 30, 2004 | 09:09 PM
panda_1's Avatar
both sides look like that one pic, for some reason the digi didnt take all of the pics.
Old Jul 30, 2004 | 09:26 PM
UMD_MaxSE's Avatar
Got Bent?
need more details on the install.... rotors? pads? calipers?
Old Jul 30, 2004 | 09:35 PM
panda_1's Avatar
ok...greenstuff pads, stock caliper, 04 slotted irotors and the blehmco brackets.
Old Jul 30, 2004 | 10:25 PM
scopium
are your rotors on the right sides...
i was considering getting the kit..
and what do u mean as griding.. like "squeal" ..
maybe the pads need to brake in?
Old Jul 31, 2004 | 10:24 AM
kwd2kSE's Avatar
Is it my imagination, or does it look like one of the bolts that holds the caliper to the bracket is just a shade too long and is contacting the rotor. Kind of hard to tell from the picture, its not too clear for making out detail. If this is the case, might want to add one more washer to each of the caliper mounting bolts. The kit with the stock calipers has very tight clearances, and just different thickness washers, rotors with more material at the hub, etc. could cause this sort of issue. Let me know if this is the problem and it fixes it. FYI, my car was the test mule for both front brake kits-the rear also.
Old Jul 31, 2004 | 10:43 AM
Colonel's Avatar
Old Fuddy Duddy
It also looks like the metal dust shield is draggin on the backside of the rotor.
We need more pic's. I want to see both sides, as kwd2kse indicates showing the washer placement. If you dont do it right...youll get all kinds of racket.
Old Jul 31, 2004 | 08:44 PM
Matt93SE's Avatar
STFU n00b!
check the stuff they mentioned, then take some more pics and PM/email me, and I'll help you through it. looks like a minor install goof.
Old Aug 1, 2004 | 06:57 AM
irish44j's Avatar
retired moderator
Almost definitely the dust shield (the metal thing that's behind the rotors) rubbing. I installed my and a buddy's BlehmCo sets and the heat shield rubbed on both of them....you just need to bend it back away from the rotor and the noise will be gone.
and you need some better pics...the one you posted doesn't really show much....
Old Aug 1, 2004 | 08:19 AM
panda_1's Avatar
well got them installed friday night, then slammed into a tree saturday afternoon http://members.cardomain.com/30585 only 1 pic but i think it can be repaired.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
wyobbagy
Aug 15, 2015 02:28 PM
