Spark plugs change at 100K or sooner?
Old Aug 21, 2004 | 04:43 PM
Whtmax'01's Avatar
Nissan recommends changing spark plugs at 100k, is this too long to wait to change them? Also is the pcv valve important to replace periodically?
Old Aug 21, 2004 | 05:04 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
ive always believed nissan recommendations are tuned towards showing a car that needs very little maintenance. the truth is if you want your car in good running condition then plugs should be changed before then. of course, they are only part of the whole picture. i replaced my plugs with coppers @ 30k which had a good amount of wear. i replace my plugs every 15k with coppers. also replaced pcv @ 40 and mine was stuck closed. if you want a plug that will have longer life then go for the stock platniums.
Old Aug 21, 2004 | 05:12 PM
ZIPPIN's Avatar
Mauja He Mauja
even the stock platinums should be changed bfr 100K. i changed mine at 66000 and again at 100k. she was mis-firing like crazy..
Old Aug 21, 2004 | 05:57 PM
pfactor172's Avatar
I just change mine at 56000 and they look like they had plenty of life left. The electrodes were worn down just a tiny bit.I put on a set of denso Iridium plugs. They were only like $2 more then the ngk.
Old Aug 21, 2004 | 09:40 PM
chinaonnitrous1's Avatar
plugs...30k..period. 100,000 miles if you drive at no more than 2500rpm.
Old Aug 21, 2004 | 09:51 PM
DonGfun's Avatar
VW = 30 MPG
106K and never had a problem 30K my a**
Old Aug 21, 2004 | 09:57 PM
thats just it, 106k I'll bet if you do a before and after dyno, and MPG comparison, you would see a benefit.. Thats not necssarily a problem, but its a benefit.
Old Aug 21, 2004 | 09:59 PM
DonGfun's Avatar
VW = 30 MPG
at first my gas milage went to sh*t
for about 3 tanks
Old Aug 22, 2004 | 03:41 AM
nyautostyle's Avatar
what set of spark plugs would u recommend then, the stock platinum or 'denso Iridium plugs' ? anyone?
Old Aug 22, 2004 | 08:23 AM
ZIPPIN's Avatar
Mauja He Mauja
i say stick with stock ones. i used iridiums and had problems.
Old Aug 22, 2004 | 10:40 AM
FusionAcid's Avatar
i changed mine at 60k. Actually raised my performance of my car. big time difference.
Old Aug 22, 2004 | 10:50 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
I did mine at 60, OE Nissan NGK Plats with recomended heat range. Also put in new coil packs at the same time- which didn't need to be repleaced, but betta safe than sorry
Old Aug 22, 2004 | 05:52 PM
Seelow's Avatar
I changed mine at 80k and they were shot. It only takes a few mins to change them so why not? You can also take them out and check them. But I would say every 30 or 40K.
Old Aug 22, 2004 | 06:09 PM
† ErV †
Since the rears are a hell to get to, i pulled one of my fronts a few weekends back and they looked mint. Not sure if the previous owner had them changed but i know that i drove 40k with the current ones. Maybe i'll change them in another 50.
And i'll side with don, 30k my ***. If you need to change them you have some other issues with your engine/fuel. Same as when people say to change your shocks every 50k.. wastage of money.
Old Aug 22, 2004 | 08:04 PM
cjden20thAE's Avatar
How do u even get to the front ones? I am far from good with that stuff but do i just take the AE engine cover off and then get to them that way? Do i need special tools? I am almost at 40k and wanna check em out
Old Aug 23, 2004 | 04:19 AM
sloppymax's Avatar
10mm open ended wrench or just a socket. two on top, two on the bottom and the cover will lift up. once the cover is out of the way, the front ones are very easy to do but the backside ones have limited clearance but can easily be worked around.
Old Aug 23, 2004 | 06:18 AM
SkoorbMax's Avatar
30k is overkill on plats. Commonly people are recommending 60k for the OEM plats.
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
