MAF and ECU reset question
Old Aug 26, 2004 | 08:34 AM
mtboulder's Avatar
I have a 2000 Maxima. It has 55K miles on it. It is starting to hesitate when I step on the gas and seems to take a long time holding the gas pedal down to get the revs up.
Question: If I install a new MAF do I have to get the ECU Flashed for the new program (recalibrated)? What happens if I do not get the ECU flashed?
Old Aug 26, 2004 | 08:55 AM
kobalt's Avatar
try cleaning out the throttlebody - it solved my hesitation problems
Old Aug 26, 2004 | 09:11 AM
twllin's Avatar
2k with those problems sounds like ignition coils to me. Same thing happened when mine went out. I can get them for 260 to your door instead of payin 600 at the dealership if that happens to be the case
Old Aug 26, 2004 | 09:16 AM
mtboulder's Avatar
Replaced the ignition coils one month ago. Fixed the pinging but not the hesitation.
Old Aug 26, 2004 | 10:06 AM
twllin's Avatar
Hmmm thats weird. U change the spark plugs too?
Old Aug 26, 2004 | 01:07 PM
ZIPPIN's Avatar
Mauja He Mauja
change the pcv, air filter, clean the throttle body, check VIAS. if you change the MAF, leave the -ve battery disconnected over night
Old Aug 26, 2004 | 03:58 PM
mtboulder's Avatar
I did change the spark plugs and air filter. I cleaned the pcv but will try replacing it. What are VIAS? How do you clean the throttle body?
Old Aug 26, 2004 | 04:45 PM
rifemax00's Avatar
I have a 2000 SE and was having the same exact problems. A buddy of mine works at a local Nissan dealership and replaced my MAF and flashed the ECU for 170 bucks. The hesitation is gone, and the car runs much stronger. He suggested taking off my intake because it allows larger particles of dirt to affect the MAF. I haven't decided what I'm going to do as far as that is concerned though.
Old Aug 26, 2004 | 05:29 PM
irish44j's Avatar
retired moderator
clean the throttle body...that completely got rid of the large hesitation I had....
here's how, courtesy of soonerfan:
http://www.cardomain.com/memberpage/335422/8
it's really easy to do..
Old Aug 26, 2004 | 07:39 PM
ZIPPIN's Avatar
Mauja He Mauja
irish, when you changed the MAF, did you get the ECU flashed by the dealer???
Old Aug 26, 2004 | 07:53 PM
irish44j's Avatar
retired moderator
no. in fact, i didn't even reset the ECU by unplugging the battery. car runs purrrrfect.
I might, though, reset the ECU this weeked and see if my gas mileage improves any...I usually only get 22-23 mpg city/hwy mix, which I think is a little bit low....
-ReLLiK-
Apr 29, 2016 06:25 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 10, 2015 09:35 PM
Colossus
Sep 9, 2015 05:46 AM
