How hard is it to replace a clutch?
Old Sep 1, 2004 | 02:17 PM
ihavea5spd's Avatar
it's going to cost me about $600 to have a shop replace my clutch. is this an easy enough job to do in a weekend? i have never replaced a clutch before.
Old Sep 1, 2004 | 02:25 PM
Kiosk's Avatar
its a major job, specially w/o a lift and air tools. Dont let anyone tell u otherwise!
Unless you are ready for a "full" weekend of work dont get into it, specially if u have never done it before (its also a two person job w/o proper tools)
Old Sep 1, 2004 | 02:47 PM
ihavea5spd's Avatar
yeah, i kinda figured. i just found a shop that'll do it for $450.00.
SOLD.
Old Sep 1, 2004 | 02:56 PM
Jeff92se's Avatar
I'm needing a caw
Look at this site. VERY good info.
http://www.motorvate.ca/mvp.php
Old Sep 1, 2004 | 03:01 PM
ihavea5spd's Avatar
LOL! thanks, but i got to the "first you must remove transmission" part, and
decided to punt. i'll be dropping the car off at the shop in the morning.
$450.00 / 6 month or 6,000 miles warranty. good enough.
Old Sep 1, 2004 | 03:03 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I do them in Chicago for 350 :P And I warranty my work. I just posted a big *** post on how to do a clutch on a Maxima. It shouldn't take them more than a hour-2 hours tops to do a clutch on a Maxima.
Old Sep 1, 2004 | 04:53 PM
ihavea5spd's Avatar
i remember seeing that thread. great info, but a little out of my leaugue. if i was a little closer, i'd have you do it. do i have to worry about them putting crap parts in my car? what kind of clutch do you put in? any i should stay away from?
Old Sep 1, 2004 | 05:07 PM
scopium
just tell your self this.. if u are asking how hard it is.. then you shouldnt do it your self
Old Sep 1, 2004 | 05:18 PM
swiora's Avatar
How many miles do you have on your car? I'm just wondering how much longer mine might last.
Old Sep 1, 2004 | 05:51 PM
ihavea5spd's Avatar
SCOPIUM, very good point.
SWIORA, about 80,000. a clutch should probably last longer than that though. could have something to do with me holding it on hills with the clutch and stuff. (i know, i know)
Old Sep 2, 2004 | 06:53 AM
Colonel's Avatar
Old Fuddy Duddy
...It shouldn't take them more than a hour-2 hours tops to do a clutch on a Maxima.
You forget, you just have a "tad" bit o' experience in that area of a car.
Old Sep 2, 2004 | 10:11 AM
Max_Gator's Avatar
The instructions for doing a clutch on that site are of little value unless you ALREADY know what you are doing.
Old Sep 2, 2004 | 10:25 AM
Max_Gator's Avatar
If you can do it in 2 hours .
To qualify what blackbird is saying it could be done in 2 hours IF Whoever did it:
- knows EXACTLY what they are doing on a Maxima;
- is using air tools
- has all the correct tools to do the job;
- has all the correct tools to deal with problems such as: a heavy duty impact wrench to get the damn stuck lower strut bolts off; a puller to get the damn stuck wheel hub off, etc.
- the proper seals for the axles;
- and whatever I haven't encountered yet.
Now, if you are like me and learning how to do it using the service manual and Haynes manual . . . break the gear selector sensor tab pulling it out . . . have to get a stronger impact wrench to get stuck bolts off . . . it is likely you can't finish in a weekend - LOL!
I will say it is fun to learn the job if you have alternative transportation.
Old Sep 2, 2004 | 10:33 AM
Jeff92se's Avatar
I'm needing a caw
Yup 2 hours is possible if you have a lift and a tranny jack. You would also might have to skip some steps like not removing the P-side axle. You would also be moving like the wind with the air tools haha.
Old Sep 2, 2004 | 10:34 AM
350 for labor, I leave it up to ya guys as to what kinda clutch you want in your car. I CAN get you the Nissan clutch cheap, or I would just recomend a ACT clutch and be good for quite a few miles. I myself will destroy a clutch in around 30K miles. And I do NOT slip the clutch at all. I do trannies for a living- just put a tranny into a 3.2TL and chill on the .org durring my lunch break
Old Sep 5, 2004 | 06:33 AM
Max_Gator's Avatar
Blackbird -
Any suggestions on how to get the drivers side wheel hub off the axle if it is being stubborn?
I've tapped/banged the hell out of it (trying not to tear up the threads) - hit it with liquid wrench numerous times but can't get it off. FSM calls for a puller so I guess I could try to rent one, after Frances leaves Florida this week.
When I look closely at it, it appears as if the teeth on the hub are a bit twisted - perhaps from too many hard launches . . . . Passenger side didn't look like that.
...The answer is to get the puller. Of course, like anything I had to get 3 before one worked right. The first, cross threaded; the second was bent; and the third I had to drive all over town to find.
CorollaULEV
30
Aug 9, 2021 08:11 PM
vanebecker
Aug 17, 2015 08:24 PM
carlosvq30
Aug 17, 2015 11:32 AM
