Brakes Issue
Old Sep 2, 2004 | 05:12 AM
aku111's Avatar
Brakes Issue
Maybe someone can help me out here. I replaced my brake pads and roters. Now it constantly squeaks everytime I brake gentelly. If I slam brakes, no noise. I also tried anti-squeak jel with no luck. Anyone have any suggestions?
Thanks in advance
Old Sep 2, 2004 | 07:18 PM
joebob's Avatar
Same problem, can anyone help?
Old Sep 3, 2004 | 05:25 AM
Jeff K's Avatar
What is the pad and rotor combo did you installed?
I installed Power slot rotors and Porterfield brake pads and had really bad noise under light braking. I changed the rotors to OEMs and no more noise. Stock rotors and most aftermarket brake pads should create no noise. If they do make noise there, is a breakin period that you need to get through. Most likely it's the brake pad material and the type of rotor that you choose that's causing your noise. I hear that ceramic is one type that is suppose to make less to no noise on aftermarket rotors.
Old Sep 3, 2004 | 05:37 AM
aku111's Avatar
I have OEM rotors. I am not sure in my case breaking period applies anymore. It's been about 3 months and issue still exists. I'll check which kind of break pads I have.
Old Sep 3, 2004 | 05:45 AM
SkoorbMax's Avatar
I would think that there is a big chance of this being caused not by the pad and rotor contact, or the caliper and back-of-rotor contact, but rather the pad's end points and where they contact the caliper/brackets/whatever they're called. You know how the pad is held in place on either end, and it slides into brackets? From what I understand, that can be a frequent cause of squeeling. There may be a spray or something that you can apply there.
Old Sep 3, 2004 | 05:56 AM
ZIPPIN's Avatar
Mauja He Mauja
ceramic pads have done wonders. minimal dusting, and noise
Old Sep 3, 2004 | 08:42 AM
MaximaPolak's Avatar
I'm getting me some OEMs for my iRotors.
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
bbsitum
Sep 11, 2015 04:55 PM
pktaske
Sep 4, 2015 08:40 AM
