I might have a problem...
Old Sep 6, 2004 | 11:28 PM
looslip's Avatar
Horra!!
I was turning into a parking spot today and clanking sound came from what seemed to be my front driver side strut. I tried reproducing it and it would only happen when my wheel is turned extreme left and I was accelerating. What do you guys think this could be? Spring unseated, blown struts, etc?
Old Sep 7, 2004 | 01:06 PM
looslip's Avatar
Horra!!
bump. Anybody?
Old Sep 7, 2004 | 01:09 PM
MarkyD's Avatar
CV Joint maybe? is it 6 speed?
Old Sep 7, 2004 | 01:33 PM
SkoorbMax's Avatar
It's a CV joint, almost certainly. That's a pretty textbook sound that a busted one makes AFAIK. Replacing it entails replacing the axle on that side, I think. At least that's what the guys on "two guys and a garage" did on the weekend
Old Sep 7, 2004 | 01:37 PM
wngan9447's Avatar
Chicken Feet Croo!
I would agree thats its a CV joint... Try to cut the wheel hard left and throw it in reverse, this puts the most stress on the CV Joint... you will get the same reaction
Old Sep 7, 2004 | 02:04 PM
MAXINXS's Avatar
It does sound like the cv joint, but I'd be surprised if the boot was already ripped on your 03. Go into an empty parking lot and turn the wheel all the way to the left and do some slow circles. Try it turning to the right and doing the same. If you hear a knock.... knock... knock, it is probably your cv joint. Look underneath the car on the affected side and look at the boot right before where the axle meets the wheel. If the boot is ripped, the cv joint needs replaced.
Old Sep 7, 2004 | 02:25 PM
looslip's Avatar
Horra!!
Thanks guys. I'll try your suggestions out tonight.
Old Sep 7, 2004 | 02:26 PM
JdoubleOe703's Avatar
teddibear703
strut bearing
Old Sep 7, 2004 | 02:28 PM
looslip's Avatar
Horra!!
any way to discern between a problem between the strut bearing and a CV boot?
Old Sep 7, 2004 | 03:15 PM
Zero Deuce SE's Avatar
I had a noise coming from my 02 when I made 90º turns into a parking lot. It was a bad strut that was replaced under warranty. Your noise is probably the same as mine was. A busted (dry) CV joint will normally be nosiy at all times the wheel is moving. There will also be grease flung onto your fender lining when the CV boot gets torn.
Old Sep 7, 2004 | 03:42 PM
looslip's Avatar
Horra!!
damn l think it might be my strut then. I've had problems installing that one strut (Its aftermarket) and I guess my ghetto rigging may have caused these problems.
Old Sep 7, 2004 | 03:48 PM
E55AMG2's Avatar
Wat
cv joint for sure...
Old Sep 7, 2004 | 03:50 PM
Why are you so sure?
Old Sep 7, 2004 | 04:10 PM
looslip's Avatar
Horra!!
I'm not so sure that its my CV boot b/c my max is relatively new. 36k miles. What makes me more suspicious of the strut is that it wasn't installed well and I had to redo it a couple of times.
Old Sep 7, 2004 | 06:05 PM
NuJerseyDrive's Avatar
Do you mean the steering wheel or the actual wheel (tire)?
My CV joint needs to be replaced soon and it only clicks when the steering wheel is turned completely to the right. During normal driving theres no clicking.
Old Sep 7, 2004 | 06:11 PM
I'm talking about while you're driving the car down the road. Especially at highway speeds. The dry joint will make a howling sound when all of the grease has beed flung out of it. Your CV joint may or may not need to be replaced depending on how much wear it has and how much grease is left in it. It needs to be dissasembled and inspected before replacing it outright.
Old Sep 7, 2004 | 06:17 PM
E55AMG2's Avatar
Wat
Mine were completely destroyed, along with the bearings, and they only made noise when you turned. It has happened the same way on all 3 of the maximas I have owned. That is how im so sure charliekilo.
Old Sep 7, 2004 | 07:12 PM
MAXINXS's Avatar
If it is making noise, it needs to be replaced as the damage has already begun. If you catch the problem early and your boot is ripped but there is no noise yet, then you can regrease the joint and install a new boot.
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
