Croaking sound when I turn steering wheel all the way left. Help. =(
Old Sep 10, 2004 | 04:38 PM
NYPD-Arnold's Avatar
Z
I'm hoping this has nothing to do with the suspension upgrade, but when I make a really tight left turn (when I turn the steering wheel all the way left) and let off the brake just a bit I hear like this...sort of burly-ish croaking noise come from the driver's side of the car behind the wheel. What the hell is it? It doesn't happen all the time, only twice so far. Also, only when I turn slowly.
What's the deal?
Old Sep 12, 2004 | 08:23 AM
Larrio's Avatar
The Definitive AE Master
i have/had either the same/similar problem. Could you tell me your suspension setup? I assume strut bearing, however I can't be certain
Old Sep 12, 2004 | 08:31 AM
MacAlert's Avatar
I got the same noise. I am running Maxspeeds w/ Tokico Illuminas.
Old Sep 12, 2004 | 08:41 AM
BP2K2Max's Avatar
is it like a crunk-crunk-crunk kinda sound that progresses as you turn the wheel? i had a similar noise when i did my H&R's & illumina's. the problem was an improperly installed strut bearing.
http://www.motorvate.ca/mvp.php/703
Old Sep 12, 2004 | 08:44 AM
† ErV †
i think this was said to be coming from the power steering pump as it is too close to somethin in the steering (i am saying what others have said). Heck i've had it for over 40k so if it were a suspension issue you would figure it would have gotten worse by now..
So yes, it's normal
Old Sep 12, 2004 | 09:29 AM
Ghase's Avatar
What's the deal?
I had the same problem, I just grease the pin in the center hub in the front. And spread some WWD-40 on the strut mount. That work for me, but 5 month later it came back. So I just did it again. There mite a better way to doing all of this, I just don't know it!!!!!!!!!!!LOL
Old Sep 12, 2004 | 11:19 AM
Z
Argh. I was told it may also be the steering belt. The croaking noise also happens if I turn the wheel while my car is idle.
Old Sep 12, 2004 | 03:59 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
When you put the strut mount back on the top did u make sure the put was facing out towards the fender...
i made this mistake and the out was off a little and i had a creaking nise and i ended up having to replace the strut bearing....
but just check if the out is facing out
that should fix the problem
-J
Old Sep 12, 2004 | 04:28 PM
mjg's Avatar
mjg
also, takes a few days for your struts and shocks to settle in, maybe it will go away?
Old Sep 12, 2004 | 07:42 PM
Z
Cubanato: I didn't do the install. I had a nearby show do it.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
