Timing belt/chain experience
Old Sep 15, 2004 | 04:55 AM
nikemike's Avatar
Just wondering what the consensus is on the mileage to have your timing belt/chain replaced? Also, I've heard stories of it costing upwards of a grand so post any costs incurred if you've had it performed already.
Apologies in advance if this is
Old Sep 15, 2004 | 05:13 AM
mzmtg's Avatar
Minister of Silly Walks
The belt usually goes before the chain. But it's way cheaper, so it's not that big of a deal.
Old Sep 15, 2004 | 07:16 AM
schernov's Avatar
I used to have a 86 honda CRX. Timing belt/waterpum was $300.
Old Sep 15, 2004 | 09:25 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
It should run about $300 with factory parts... maybe cheaper with aftermarket parts
Old Sep 15, 2004 | 09:46 AM
dmplus's Avatar
Maxima's have a timing chain that should outlast the engine.
Old Sep 15, 2004 | 09:53 AM
mzmtg's Avatar
I don't know who would have told you that.
Old Sep 15, 2004 | 09:54 AM
dmplus's Avatar
Every single mechanic and dealer i have talked to in the 10 years i've owned maximas
Old Sep 15, 2004 | 10:02 AM
mzmtg's Avatar
Rrrrriight...
I had my mechanic change the belt in my VQ at the same time he swapped in new spark plug wires.
Old Sep 15, 2004 | 10:05 AM
dmplus's Avatar
going to assume you mean accessory belt and not timing belt, since vq's dont have timing belts. So yes, i've replaced several belts on my maximas. very inexpensive probably 20 bucks or less.
Old Sep 15, 2004 | 10:06 AM
mzmtg's Avatar
Well, then I got ripped off if he charged me $400 to do the regular belts when he told me it was the timing belt.
Old Sep 15, 2004 | 10:08 AM
Kevlo911's Avatar
Kevlo for President
Ben stop messing with them, they are already confused, why make it worse
Old Sep 15, 2004 | 10:10 AM
wngan9447's Avatar
Chicken Feet Croo!
Timing chains are to be changed at 200,000 miles or when the tension slowly starts to give... so many think that it should outlast the life of the car... i had an Altima before my max and that got up to 250,000 miles without a chain replacement... Nissan recommends checking the timing chain every 100,000 miles... whats this about a timing belt? We have serpentine belts that drive the water pump, A/C compressor, alternator, etc., but no timing belt.
Old Sep 15, 2004 | 10:11 AM
mzmtg's Avatar
Quiet you!
Old Sep 15, 2004 | 10:13 AM
Kevlo911's Avatar
Kevlo for President
Delete my post and have fun
Old Sep 15, 2004 | 10:26 AM
wngan9447's Avatar
Chicken Feet Croo!
If your mechanic told you that he changed your timing belt...SMACK HIM!
Old Sep 15, 2004 | 11:25 AM
maseo77's Avatar
I second that.
A few of my dumba$$ die hard chevy friends lost $100 bucks to me when they swore I had a timing belt, I had to drive them to the dealership and ask 2 mechanics b4 they stopped laughing at me for saying I had a timing CHAIN
Old Sep 15, 2004 | 11:35 AM
Kevlo911's Avatar
Kevlo for President
I think you need new friends.
Old Sep 15, 2004 | 11:49 AM
StillenMax80x20's Avatar
i second that kevlo, quite a few chains on cars these days, they're stuck in the carb age
Old Sep 15, 2004 | 11:57 AM
SkoorbMax's Avatar
There is no schedule for replacing a timing chain. If anybody disagrees with that I defy them to find an official recommendation from Nissan. Otherwise, do not change it unless it causes you problems.
Old Sep 15, 2004 | 12:11 PM
wngan9447's Avatar
Chicken Feet Croo!
I agree... my buddy who is a Nissan mechanic said that he has seen them lose tension at around 200,000 mile... remember my Altima went pretty far before I got rid of it... I doubt it got resold, but if it's on the road today, i bet it still has the same original timing chain on it.
Old Sep 15, 2004 | 12:35 PM
I30tMikeD's Avatar
I thought we had a chain driven timing belt
Old Sep 15, 2004 | 02:51 PM
Robdog69's Avatar
I was a Nissan technician, here in OH, for Buckeye Nissan, and for the 2 years I worked for them, I did not replace a timing chain on any maxima, I had replaced timing chains on altimas, 95 and below, other then that I did a lot of timing belts for pathfinders and xterras. Just keep fresh oil in there and you should be just fine for about 200-250k miles. I do rec: that people that have 95 altimas remove there plastic guides at the top of the motor under the valve cover where the cam sprockets are, due to the fact they end up breaking and causing noise and then getting trapped inbetween the sprckets and chain and causing more damage in the long run. Just some advise.
Old Sep 15, 2004 | 04:57 PM
Progress's Avatar
It's business time.
But you have to replace the little gerbal the powers the radiator fans. I haven't replaced mine yet but I remember to feed him every 4k miles or so. Oh and don't forget that blinker fluid.
Old Jan 23, 2008 | 02:59 PM
tofer85's Avatar
Hey guys, old Mustang guy here. Never really have broke into too many Nissan motors, but my water pump went out a week or so ago, and I'll be danged if I can see how the pump comes out of that freaking inspection plate, so I pulled the front cover off...... The thing is, I'm not sure if I jumped a tooth or not before the cover came off, when I was working the crank back a bit to get slack on the water pump....I've seen in some of the timing chain posts that there are dark links that line up with the arrows on the cam gears, and a lighter link for the crank gear. Well my chain has two "yellow" colored links, and I cant see any that look darker, period. Anyone have any advice on this at all? I have decided to go ahead and replace the tensioner as well, which should be in the morning.....so somebody please help me out with this???
Old Jan 25, 2008 | 06:38 PM
NisTech's Avatar
They could have slack and cause incorrect timing- fail emissions. However that is like 1 in 100 at 200,000 miles. Like it has been said chains outlast engine life.
Old Jan 25, 2008 | 06:40 PM
NisTech's Avatar
read the ESM and follow it. Don't let someone give you advice on timing chains. Line up everything from the beginning and you should be fine.
And the pump does come off without having to re&re the sidecover.
SoonerFan's Avatar
Cletus
thanks for the bump of the old *** thread
Old Jan 25, 2008 | 06:49 PM
NisTech's Avatar
?? why would you thank me?
Old Jan 25, 2008 | 06:54 PM
SoonerFan's Avatar
Cletus
it was a joke.
the questions had been answered....thread dropped...you brought it back. why
Old Jan 25, 2008 | 06:58 PM
NisTech's Avatar
perhaps cause you can do the waterpump without taking the whole side cover off saving a good flat rate type tech with airtools at least 4-5 hours.... and a tube of gasketmaker that costs $15....
Old Jan 28, 2008 | 11:25 AM
tofer85's Avatar
Man I tried for hours to get the pump out of the inspection cover....seemed like I just couldnt get the chain out of the way enough. It would bind between the pump and timing cover when I tried to pull the pump out...anywho....got it in now...after removing the cover. Buttoning everything up now...Thanks Guys.
Cotozic
Jun 28, 2017 08:01 PM
bk2k3max
Sep 17, 2015 09:39 PM
adamgalazka
Aug 31, 2015 05:55 PM
FlaMark
25
Aug 28, 2015 10:15 AM
scutmud
Aug 28, 2015 05:04 AM
