Remote start installation.
Old Sep 21, 2004 | 06:04 AM
98i30's Avatar
My dad got himself 2K Maxima. And he wants me to install remote start.
I did it in our 3 other cars (98i30, 2000corolla , 96civic), but 2K got “chip” in the key, so my question is there a way, or anybody done that? Is there “how to” or “sticky”?
Old Sep 21, 2004 | 09:53 AM
myktek's Avatar
u have to get a box for your key in order to bypass it..... or u can do it ghetto like me, cut up your spare, wrap copper wire around it and and wrap that wire around the key hole.... tricks it into thinking that the key is inside.... =)
Old Sep 21, 2004 | 10:40 AM
fornimage's Avatar
Yes it's been done. I've got it on my 2002 6-speed. You'll need to buy a bypass kit and sacrifice the valet key to get it done but now I here you don't have to cuz there is a product out there that is suppose to memorize the code. I forget the number of the bypass kit but it's pretty much universal...check the web for one. Have you checked the how-to section yet for a write-up? If you've done remote starters on other cars then you should be able to do a Maxima...all you need is the wiring diagram. I can dig one up for you if you need one.
Old Sep 21, 2004 | 11:02 AM
98i30's Avatar
I did check "how-to" section for a write-up, but couldn't find anything.
Thanks for the info!
Old Sep 21, 2004 | 11:25 AM
RAZORFISH228's Avatar
If you could pass along the information for the code or where to buy the bypass kit, that would be great.
I am trying to get a remote start on my 03SE as well.
Thank You
Old Sep 21, 2004 | 11:33 AM
PearlWhtMaX2000's Avatar
all u need is amudule its the 556U module. its about $40
Old Sep 21, 2004 | 04:24 PM
StAtiXz6's Avatar
is it smart to put a remote start on a 5 speed car???
Old Sep 21, 2004 | 04:37 PM
2kSC's Avatar
Smart? Hell no, j/k I am planning on doing it.
Just make sure not to put it in 1st when you park and don't let anybody else use the remote or the car.
Old Sep 21, 2004 | 05:03 PM
xtantmaxima's Avatar
A few years ago Clifford came out with a product especially for manual transmission vehicles. It was supposed to make sure the emergency brake was engaged and the vehicle was not in gear. To be able to remote start the vehicle you had to park the vehicle and engage the remote start, exit the vehicle, lock the vehicle which also shut down the motor. This way when you get back it would allow you to activate the remote start, not conveinent, but safe. You could buy a normal kit but just make sure it's never in gear.
Old Sep 21, 2004 | 06:39 PM
StillenMax80x20's Avatar
the 556u is the only unit i've heard of, but it just transmits the code from the key inside the car. I've read in my Haynes that there's a gear position sensor right in the transaxle, but not sure how it works. Most likely there is a way to run the neutral saftey shut down through that. otherwise, get in the habbit of leaving it in neutral, and you'd have to bypass the clutch-to-start switch
Old Sep 21, 2004 | 07:06 PM
StAtiXz6's Avatar
could any of u link me to that model?
Old Sep 21, 2004 | 08:59 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes a 555U or the newer 556U is needed for the key bypass.
The neutral safety wire is Green/white stripe located in the engine bay. Using that, it will Not start if left in gear. I just finished doing another one yesterday.
--Don
Old Sep 22, 2004 | 11:52 AM
fornimage's Avatar
Trust me...make sure you tie into the PNP(Park Neutral Position) sensor with the remote starter if you plan on installing one on a manual transmission car. I learned the hard way when I got lazy and decided to skip this step cuz I never leave the car in gear...poor bumper.
Pin #44(green/white?) on ECU:
With the car off and in gear, the PNP sensor sees an open ground.
With the car off and not in gear(neutral), the PNP sensor sees a ground.
You want to connect the ground wire of the remote starter to this wire...no additional relays are needed.
In addition while driving, the PNP sensor sees ~5VDC when in gear so you may need to add a diode on the ground wire of the remote starter to prevent the SES light from coming on...the code will be related to the PNP sensor. I had this problem when I first did the remote start but by adding the diode it has stopped since.
QueensMAX
Sep 15, 2015 04:14 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
Johnny9595
Sep 3, 2015 05:18 AM
