brake pad replacement
Old Sep 25, 2004 | 03:38 PM
NoMotive's Avatar
i'm looking for any write-ups on brake pad replacement. and are there any other brands that i should look for besides nissan oem replacement?
Old Sep 25, 2004 | 03:44 PM
Edward Lee's Avatar
Performance Friction Z-Rated!
Old Sep 25, 2004 | 03:57 PM
skalberti's Avatar
I live life on the edge
whatever you do........ go with a good quality ceramic. Just make sure they are a high content ceramic and not a cheap version.
Old Sep 25, 2004 | 05:30 PM
Edward Lee's Avatar
Whatever you do, stay away from CERAMIC PADS. They can't hold enough heat and end up warping your rotors prematurely. The only benefit that a creamic pad supposedly has is less squeaking and less dust. They are good at eliminating the squeaking but as far as dust, I have noticed no difference between a ceramic pad and a semi or carbon metallic. Besides, if you do a good job on your brakes, they should not squeak at all.
Ceramic pads can't stop your car as fast as a semi or carbon metallic. Ceramic pads do not hold temps as well as a semi or carbon metallic.
Since the ceramic pads don't hold heat as well, the heat has to go somewhere and the rotors are the most likely candidate to take on this burden causing them to overheat and warp.
If you would like more info on this, give the guys at Diversified Cryogenics a call or call someone at Performance Friction, they'll set you straight.
Good Luck
Old Sep 26, 2004 | 12:08 AM
aussie983's Avatar
brake replacement: www.motorvate.ca
porterfield r4s
Old Sep 26, 2004 | 12:40 AM
NoMotive's Avatar
nice... good website
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
