Replacing Reverse light switch. Anyone done it?
Old Sep 30, 2004 | 10:08 AM
nicks79's Avatar
2000 maxima, with 5 speed. When I put it in reverse gear, lgiths on the back don't light up. If i wiggle with shifter a bit, they may go on, but won't stay. Was diagnosed with faulty or bad reverse light switch.
Has anyone replaced it? I think its under the car next to transmission. Any suggestions? and is it a complex thing to do?
Thanks ahead.
nick
Old Sep 30, 2004 | 11:24 AM
oldngivout's Avatar
Willing to learn
It goes in the transmission, outside on the bottom. Looks like a black plastic plug with a wiring harness coming out of it. Cheap to buy at the dealer, and fairly easy to replace, just one small bolt and one electrical connection.
But beware, removing it will completely drain your transmission of fluid, so you must catch it in something to avoid a huge mess.
Old Sep 30, 2004 | 11:28 AM
nicks79's Avatar
So I would have to replace Transmission fluid. I don't mind that, but is that commonly done on Manual tranny?
Thanks.
Old Sep 30, 2004 | 01:51 PM
Colonel's Avatar
Old Fuddy Duddy
Thanks.
Should be. Recommended change interval is about 30K...some preliminary tests show that 30K is to long to leave it in and should be closer to 20K. I change mine once a year <15K. Its easier than changing your motor oil.
Old Sep 30, 2004 | 04:16 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Mine is doing the same thing, the lights tend to take like 2-3 seconds to finally turn on and I diagnosed it myself that its the reverse /neutral safety switch. 1 10mm bolt holds it in place. I change my Redline ShockProof gear lube every 30K miles, and its fine.
Shock_and_Awe
Aug 23, 2015 01:02 PM
KristyKarina
Aug 23, 2015 09:53 AM
spidgeon
Aug 18, 2015 05:46 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
