tcm
Old Oct 3, 2004 | 03:02 PM
myfirstsix's Avatar
tcm
does anybody know hopw much the tcm costs on a 2000se? cant find it anywhere.thanks
Old Oct 3, 2004 | 03:33 PM
Loe max's Avatar
If your looking for a new TCM, consider an I30 TCM. Why? Because that TCM is programmed to shift at redline in every gear as well as downshift into the lowest gear possible when the hammer is down.
Cost? You can call your Nissan or Infiniti Dealer.
Old Oct 3, 2004 | 06:08 PM
myfirstsix's Avatar
thanks you wouldnt have a part # would you? also will it work? connectors the same ? thanks
Old Oct 3, 2004 | 06:32 PM
Loe max's Avatar
According to DaveB and Icy2kSE, it should match right up without modifications.
Old Oct 3, 2004 | 06:48 PM
myfirstsix's Avatar
sounds good i guess i have to get the same year as my car right(2000) i ll give infiniti a call tommorrow. is this a new thing, that was just figured out? i havent heard of this. have alot of people done it. thanks again for your quick replies and info
Old Oct 3, 2004 | 06:59 PM
Haterz's Avatar
Has anyone here tried this?
Old Oct 3, 2004 | 07:26 PM
myfirstsix's Avatar
it would be cool if it did play with the revs on the auto. im going to have my stock tcm replaced on thursday after having them fix my valve body dur to slipping 2-3. now it does it in 1st when you give it 3/4 throttle. hopefully they dont give me any crap. service manager said no prob so it should be fine. if the i30 tcm works and its not mad money i might pick it up though.
Old Oct 3, 2004 | 07:55 PM
Bl_asd's Avatar
what's tcm? what does it do?..
Old Oct 3, 2004 | 08:40 PM
Loe max's Avatar
TCM=Transmission control module. It works in conjuntion with the ECU (Engine control unit) to perform transmission functions. To my knowledge, no one has tried an I30 TCM on a Maxima and I dont' see why.
Myfirstsix...There will be different part#'s for the 00-01 TCM's. One is an updated version for I30's built after 5/00 to decrease the slow 1-2shifts. I can't remember which part# is the newer one though. Its a plug-n-play item and shouldn't throw off any codes.
Old Oct 3, 2004 | 08:56 PM
myfirstsix's Avatar
cool im going to look into it tommorrow, thanks again. if you do find a part # let me know cause then i can reference it. thanks
Old Oct 4, 2004 | 02:14 PM
Haterz's Avatar
Does anyone know of the best way to get a 2000 maxima to shift at 7200 rpms. I have i/h/e with no cat/udp and i removed the restrictor plate behind the tb and it pulls the hardest up top but then it shifts. It seems like it would pull hard well past redline.
Old Oct 4, 2004 | 05:30 PM
Loe max's Avatar
Technosquare will have an ECU available shortly for 00 Maxima's. That will allow you to manually upshift to 7,200rpms. I think Technosquare should also reprogram the stupid OEM TCM imho.
dougb
Mar 3, 2011 02:52 PM
99pearlGXE
Feb 19, 2003 11:24 AM
hard8
Oct 14, 2000 10:28 PM
jnm2kse
31
Sep 7, 2000 05:45 PM
jnm2kse
Sep 4, 2000 07:00 AM
