Writeup on brakes pad replacement?
I bought a caliper compression tool from Advanced Auto Parts for 10 bucks that goes on a 3/8" drive socket wrench.
Like stated above, only two bolts hold the calipers on 17mm or 18mm socket will remove those.
The bolts are 14mm on the f/r calipers, you will need a 4 " c-clamp to squeeze in the cylinder on the front brakes. If you have all the tools, it shouldn't take you more than 25-30 minutes do your front brakes. I will do my rear brakes in another week or so after I find this special tool you attach to a socket, all my local shops are sold out.
Originally Posted by 00MaxSE
Check the How To's. It's pretty easy. Except you need to rent a disc brake caliper tool for the rears. I got mine from Autozone.
Originally Posted by KashThaRipper
shouldn't u be resurfacing ur rotors prior to installing the new pads for even wear?
^^ if they haven't worn out tho, then it's best to resurface them right?
igor911 said only pads so i assume he's keeping his rotors
how do u go about resurfacing rotors anyway
Originally Posted by Igor911
Thanks alot guys
Now what pads to get? I've had axxis MM on Stillen X-Drilled before and they sqeeled alot...
What will give me a good bite, long lasting and not too much dust?
I have IRotors with OEM pads and there is absolutely no noise.
I have SP performance rotors , X drilled and slotted with a high ceramic content pad. No dust no squeal period. Good braking, less fade than carbon fiber semi metallic pads. Someone posted some BS about ceramic pads causing a lot of heat and other crap, but the new vettes come with ceramic pads as well as a lot of other high dollar performance cars. I half to ask myself if that BS is true then why would they put them on high dollar sports cars. When you buy pads, just make sure they have a high ceramic content. There are "cheap" ceramic pads. You can see the rotors in the pic above.
12-01-2003, 12:33 AM #6 JodyBerry vbmenu_register("postmenu_2517247", true);
Maxima Enthusiast
Car: 2000 Icelandic Pearl SE
[QUOTE=Mike2000SE]Cool! Thanks for all the info guys! QUOTE]
Mike,
I recently asked this same question about brakes. Here's the response I got from one member:
An org member posted this awhile back:
Rotor & Brade Pad Installation Notes
My notes from rotor and brake pad swap without disconnecting brake lines or bleeding brakes.
Brake Install Notes:
Tools/Equipment:
• Jack & Jack Stands
• Impact Wrench or Lug Nut Wrench
• 14mm, 17mm, 19mm sockets & ratchet
• C-Clamp
• Rear Piston Compression Tool
• Mechanics Grease or Anti-Seize Grease
• Brake Cleaner
• Rubber Mallet
Front:
1. Put the car up on jack stands and remove the front wheels.
2. Remove the bolts holding the upper piece of the caliper on...14mm...these came off without any effort...slide the caliper off and hang it on the coil of the spring.
3. Remove the brake pads...they pop right off...pay attention to the way they are seated.
4. Remove bolts holding the lower piece of the caliper on...19mm...these require some elbow grease to remove, but I did not need any liquid wrench or a breaker bar...slide the second caliper piece off and set aside.
5. Remove the rotor...requires some rocking and tapping to remove...my stock rotors did NOT have a bolt hole easy removal so I did some light tapping on the back side with a mallet as I turned the rotor.
6. Install new rotor...clean up the wheel hub first and rub some grease around the hub to prevent the new rotor from rusting onto the hub like the stock one.
7. Reinstall lower piece of caliper...clean it up first to remove all the brake dust...tighten up 19mm bolts good and tight.
8. Install new brake pads...ensure that you remove the backing plates off the old pads and install them to the new pads.
9. Compress the piston on the upper piece of the caliper...loosen cap on the brake fluid resevoir by the driver's side strut tower in the engine bay to make piston compression possible...use a clamp and equally distribute pressure as you compress...watch for brake fluid overflow.
10. Reinstall upper piece of the caliper...clean it up first to remove all the brake dust...tighten up the 14mm bolts marginally (remember how easy they were to remove).
You're all done. Differences for the rears:
• You must remove the 14mm bolt holding the mount for the emergency brake cable to get the upper part of the caliper off...underneath the caliper.
• Lower piece of caliper is held on by 17mm bolts instead of the 19mm on the front.
• Piston needs to be turned clockwise to be compressed...I suppose you could use pliers, but you can buy a small piston compression tool which hooks on to a ratchet and makes life really easy...the one they sell at Sears has a piston pattern which fits the rear calipers on the Maxima.
• Make sure you hook the emergency brake cable onto the spring mechanism before reinstalling the upper caliper piece as it will be hard to hook back on after the caliper is assembled.
Maxima Enthusiast
Mike,
Tools/Equipment:
• C-Clamp
• Brake Cleaner
• Rubber Mallet
Front:
fyi, I don't use any special tools. A channel-lock plier to compress the piston for the fronts, and needle nose pliers (CAREFUL with these...) to turn the piston on the rears. I've had my brakes apart so many damn times it's not even funny. Including installing the BlehmCo kit, indexing the rotors using a dial runout gauge (mainly to verify runout, which I think I have a slight problem on the front right, that may or may not be wheel bearing-related...), etc
Cant_Get_Ryte
08-28-2015 06:41 AM
RealityCheck
08-05-2015 06:18 AM
