Installing alarm, need 2001 wire confirmation.
Old Oct 14, 2004 | 07:38 AM
GaMax97GLE's Avatar
I'm finally getting around to installing my Clifford Matrix RS2 alarm after sitting in the closet for well over a year. I've found 5th Gen wire colors online through forums that allow SEARCHES but I need someone to confirm that they are accurate.
Anyone who's done a 2001 please let me know if there is anything I should know. Also, I need to purchase the 555u or 556u.
Where did you mount all the relays and the brain?
Craig B provided me with this but it needs confirmation:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|green |+ |ignition harness |
| STARTER|black/red or blk/wht|+ |ignition harness |
| SECOND STARTER|black/blue |+ |ignition harness |
| IGNITION|black/red (smaller) |+ |ignition harness |
| ACCESSORY|red/yellow |+ |ignition harness |
| SECOND ACCESSORY|white/blue |+ |ignition harness |
| POWER LOCK|gray |- |pin 23 at SECU *1 |
| POWER UNLOCK|brown/yel |- |pin 35 at SECU *1 |
| LOCK MOTOR|purple | |pin 15 at SECU *1 |
| UNLOCK MOTOR|white/black | |pin 13 at SECU *1 |
| DISARM DEFEAT|green/yellow | |pin 14 at SECU *1 |
| PARKING LIGHTS +|red/blue | |driver kick panel *2 |
| PARKING LIGHTS -|lt. blue | |headlight switch |
| HEADLIGHTS|pink |- |headlight relay *7 |
| DOOR TRIGGER|*3 | |SECU *1 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|purple/yellow |- |pin 38 at SECU *1 |
| HOOD PIN|yellow/red |- |pin 27 at SECU *1 |
|TRNK/HTCH RELEASE|blue |*4 |pin 12 at SECU *1 |
| FCTRY ALARM ARM|orange/black |- |pin 41 at SECU *1 |
|FCTRY ALRM DISARM|orange/blue |- |pin 30 at SECU *1 |
| TACHOMETER|white/green | |instrument cluster *5 |
| SPEED SENSE|pink/blue | |instrument cluster *6 |
| BRAKE WIRE|red/green |+ |brake switch or drivers kick|
| HORN TRIGGER|green/white |- |steering column |
| WIPERS|blue(L), blu/blk(H) |- |steering column |
| LF WINDOW UP/DN|blue - green |A |drivers window switch |
| RF WINDOW UP/DN|red/wht - red/blk |A |drivers kick panel |
| LR WINDOW UP/DN|yellow - red |A |drivers kick panel |
| RR WINDOW UP/DN|grn/wht - green |A |drivers kick panel |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|yellow |+ |at radio |
| RADIO GROUND| | | |
| RADIO SWITCH|purple |+ |at radio |
| RADIO ILLUMINATE|red/white |+ |at radio |
| POWER ANTENNA|green/white |+ |at radio |
| LF SPEAKER|blu/wht - blu/yel | |at radio or speaker |
| RF SPEAKER|brown - brn/wht | |at radio or speaker |
| LR SPEAKER|lt. grn - blk/yel | |at radio or speaker |
| RR SPEAKER|blue - pink | |at radio or speaker |
Old Oct 14, 2004 | 10:09 AM
kpr10is's Avatar
Just double checked every wire you listed with Directed's tech site, which I use at work (circuit city installer). All 100% correct.
Also, http://maxima.theowensfamily.com/viper791xv/ is Studman's (Jeremy's) website, with a complete, very thorough how-to for installing the Viper 791XV in a 5th gen. Although it might be a little different since yours is Clifford, theyre both Directed so it should be similar. You should definitely pm him with any questions, he would be glad to help, knows a ton about it all, and has done plenty of these in all gen maximas.
All images copyright Directed/Directechs.com
Good luck
Kevin
Old Oct 14, 2004 | 11:04 AM
GaMax97GLE's Avatar
Thanks for the reply. Now, do you know if their Tech Sheet is correct by visually comparing the list to the actual car wires?
I've been searching http://www.the12volt.com/installbay/default.asp forums and have found a lot of great info there too and people have linked different .pdf's with install diagrams, etc.
Now I just need to pick up the key transponder and I'll be ready to start. I should be able to knock it out over the good part of a Sat/Sun and these pictures and the link help so much!
Eric.
Old Oct 14, 2004 | 11:54 PM
kpr10is's Avatar
99% of the time theyre right, but its really impossible to tell 100% of the time, which is where a digital multimeter comes in handy for voltage testing. A test light will still work, just not as safe as a multimeter, so if you plan on installing any alarms in the future, or will ever need to test resistance, continuity, coltage, etc, definitely get a multimeter. You should be fine to trust directechs though...if you are in a bind for money though, is still at least get a $5 test light so if there are two similarly colored wires in a similar location, you can double check your work.
Good luck again...alarms are always fun to learn and good to have knowledge about.
Kevin
kmitchel
Oct 28, 2015 09:46 AM
conansriver
Sep 3, 2015 06:38 AM
JMag90
Aug 25, 2015 09:17 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
