I cant get my rotors off.
Old Oct 15, 2004 | 04:11 PM
nexus_7's Avatar
I have new rotors to put on...so far I have the calapers removed and the break pad housing removed on both front tires.
THey are rusted on something fierce or something. I have hit them a few times with lock ease (used for loosing rusted on bolts and stuff) but nothing yet...HELP!
Greg
Old Oct 15, 2004 | 04:19 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
keep hitting them on opposite sides of the rotor, or there are two small holes apart from the bolt pattern that with the right bolt you can drive them in one by one and basicly pry it off.
Old Oct 15, 2004 | 04:22 PM
filtor1's Avatar
I have sat down on my butt facing the rotor and used my feet to push from side to side. You can be forcefull. They are used to it. If all else fails use a rubber mallet.
Old Oct 15, 2004 | 05:00 PM
imported_JIC_A33
bingo.........
Old Oct 15, 2004 | 05:15 PM
Tek-Niq's Avatar
hit it!!!!!!! bang..........bang.............bang............ban g...........bang..........(rotor comes off)......cling.........cling......
StillenMax80x20's Avatar
i second the rubber mallet
Old Oct 15, 2004 | 06:37 PM
wngan9447's Avatar
Chicken Feet Croo!
There are two screw holes on the rotors next to the studs... if you can find some screws at home depot, screw them in and they come out slowly.. thats why they are there
Old Oct 15, 2004 | 09:17 PM
geenowalker's Avatar
put a jack in between the rotor and stable object (ie frame or fixed member) and let physics do the trick.
Old Oct 15, 2004 | 09:38 PM
nexus_7's Avatar
well, I will let it soke over night in wd40 and my liquid wrench.
Been pounding on one with a rubber mallet...nothing has been moving. so I can wait.
anyone know what size of a screw to get for that hole if it comes to that. I dont want to be taking 30 trips back and forth to the store.
Greg
Old Oct 16, 2004 | 07:44 AM
nexus_7's Avatar
these bastards are really stuck on there.
soked them all night....pounded them with rubber happer this AM. went to store to get right threaded bolt...Stripped the bolt LOL. maybe I will just break them.
This sucks.
Greg
Old Oct 16, 2004 | 07:56 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
you have new rotors to put on anyways right ? When I do rotors on a car, I don't use no rubber mallet, I get a big azz steel hammer that I use to separate ball joints with etc. I wack it HARD in the middle a few times to let loose of the rust, then I wack it on the braking surface of the rotor a few times hard- I've broke plenty of rotors before. I never had an issue. That is the way I do them at work.
Old Oct 16, 2004 | 08:02 AM
nexus_7's Avatar
i used a normal hammer on the center area a few times. I guess I will just finish them off.
yea, I have my brembo ones sitting right here.
Greg
Old Oct 16, 2004 | 08:07 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Did you remove the lock rings from the wheel studs?
Old Oct 16, 2004 | 08:18 AM
Maximas don't have anything holding the rotors to the hub or studs, they are full floating rotors. Only thing holding them down to the hub is the wheel when its tightened down. I live fairly close by you (Schaumburg) if you don't get them off in the next hour halla at me. Do you have a BFH ? (big #$%^* hammer)
Old Oct 16, 2004 | 09:29 AM
Progress's Avatar
It's business time.
If the car is on jack stands, is it ever possible to hit it so hard with a hammer that it knocks the car loose, off the stand?
Old Oct 16, 2004 | 09:37 AM
MaximaPolak's Avatar
Did you decide to take off the caliper bracket?
Old Oct 16, 2004 | 09:46 AM
nexus_7's Avatar
Ok...I got them off, and the new ones on. drove about a mile and wll went to hell.
passanger side is having major probs. It seems like the calaper is frozen, but when I took them apart I was easly able to squish/condence it.
so I can back home and it was just radiating heat so I know that isnt right. Ugh.
Im getting pretty pissed.
Guys, it is normally easy to get these things off. remove wheel, remove calaper, and remove pad holder. then the rotors are just sitting there.
I sent you a PM BlackBIRDVQ
what a crappy day
Greg
Old Oct 16, 2004 | 10:18 AM
nexus_7's Avatar
http://forums.maxima.org/showthread.php?t=340748 those are the ones I got btw, and I just replaced my napa pads like I always do every 12months or so (life time warranty, not the best pads I am sure but what ever).
Greg
Old Oct 16, 2004 | 11:45 AM
OT n00bs FTMFCSL
You're dead a$$ wrong. My rotors, both front and rear, had locking rings/washers to hold them on from the factory. Don't know if there's any kind of difference between models or not, but mine are on there...
Old Oct 16, 2004 | 11:57 AM
nexus_7's Avatar
well, not on my 2k se.
there is that Huge nut in the middle but that has nothing to do with the rotors.
Greg
Old Oct 16, 2004 | 03:35 PM
nexus_7's Avatar
Fricken Napa.
Ok, so my calaper is shot. call up napa and ask if they have them in stock and when they close. they do and at 5pm great, I am on my way.
Get there at 4:49. doors locked. Get back in the car and call them....ask when they close, ofcourse the answer is 5pm, I say you still have 10 min, yes sir, we are closed now. I say I am in the parking log with $ and want to buy stuff...sorry sir we are closed. ARGGG!
Another day with out my ride.
Greg
Old Oct 16, 2004 | 04:15 PM
no locking rings on my 01, must be another 02-03 thing. I have done plenty of brakes on Maximas and never seen them.
Old Oct 16, 2004 | 04:53 PM
Andrew's Avatar
Originally Posted by nexus_7
Fricken Napa.
Greg
Bastards!!! 10 minutes left? I would have started to kick down the door at that time. oh well, wait till tomorrow morning when they open. When I used to work on my old commuter cars, Dad's old saying was 'work on the cars early in the morning in case you need anything from the parts stores, they will be open.'
Good Luck!
Andy
Old Oct 17, 2004 | 04:09 AM
jmal's Avatar
Typical 'Crap-A' Napa...sheesh.
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
