To everyone with Cali-spec Y-pipe:
Old Apr 12, 2001 | 06:55 PM
ArcticMax's Avatar
I just discovered today that my car is Cali spec.
consequently, I am reluctant about getting a y-pipe cause the power difference is not gonna be as much as the Fed spec.
so, I want to ask you all: did you all notice an increase in power after installing the Y-pipe? No imaginations please! did you really notice the power?
Thanks all.
Old Apr 12, 2001 | 07:17 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
I didn't notice a major difference. "Felt" more from the CAI.
Old Apr 12, 2001 | 07:36 PM
UMD_MaxSE's Avatar
Got Bent?
that's kind of why I am hesitant to get one also....since I have cali spec, I think I will wait and see if the Fed spec exhaust manifold experiment works out....
Old Apr 12, 2001 | 11:27 PM
Desert Pearl's Avatar
I am ordering the Stillen 2-piece tomorrow. I'll obviously install it ASAICWTWK. That stands for "As Soon As I Can Without The Wife Knowing"!!!!!!! Heck, I'm still trying to get my stupid underdrive pulley installed (yes Adam, it's still in my trunk!)
I am planning on getting my car dynoed next Thursday, but I doubt I will have the y-pipe by then. At least I will have good pre-conversion dyno results for comparison. I imagine I will get dyno results a week or two after I install the pipe/manifold.
Old Apr 13, 2001 | 06:52 AM
Y2KevSE's Avatar
Use my procedure to install the pulley, Phil (no air tools).
Old Apr 13, 2001 | 11:10 AM
BottleFedMax's Avatar
Yeah I agree not much difference. Not enough to justify the $400.
Old Apr 13, 2001 | 06:28 PM
Kevin, where is your procedure? I only see pics on your site. I reefed on this ***** with something wedged into the flywheel for quite a while and still couldn't break it loose. I thought I had it at one point in time, only to find out that I had broken my torque wrench (I was using it because it was the biggest **** I could find). Are you referring to the blipping of the starter method?
Old Apr 13, 2001 | 06:37 PM
slvr2KSE5's Avatar
dont use a torque wrench...u will break it as u found out. use a breaker bar, wedge it so it will loosen when the starter is bumped by a friend.
Old Apr 13, 2001 | 06:48 PM
Deac's Avatar
Got a Cali-Spec too...
I have a Cali-spec too and I just got it installed. The main thing I was worried about was the noise...alot of guys say it makes your car very loud almost like "bees in a can". I thought I was impressed by the "growl" the CAI gave my car but the Y-Pipe "growl" is even sweeter! Its not loud at all it just gives your car a deeper "growl" kinda like a muscle car growl but Nissan style!!!
I do notice a bit of a power increase also. My low-end seems more powerful, the car seems to accelerate faster but w/less effort. I think I noticed about the same increase in power from the Y-Pipe and the CAI. I got both of them from Cattman.
PS...still dont know how to make a sig!!! #(@*$&
Deac
Old Apr 13, 2001 | 06:49 PM
I wish I had a breaker bar. The biggest thing I have is my stupid 1/2" drive (maybe 13-14" long). My torque wrench was a good 4-5" longer and rated higher than the recommended torque of 140ft-lbs in the instructions. I thought if the factory put it on at the spec'ed torque, my wrench should have been fine. Oops!
Old Apr 13, 2001 | 08:59 PM
Y2KevSE's Avatar
Remember our emails back and forth? Use a breaker bar and put it up against the arm, then crank the car but don't start it. It should break the crank bolt loose. To put it back on, use a hammer and hit the breaker bar while it's on the bolt. Now do you remember?
Old Apr 13, 2001 | 11:06 PM
Gee, Kev. Based on all of the stuff on your website, I actually expected a step by step illustrated procedure like:
Step 1 - Get car keys.
Step 2 - Unlock door.
Step 3 - Sit in car.
Step 4 - Put keys in ignition.
Step 5 - Turn ignition clockwise three clicks.
Step 6 - Immediately turn ignition CCW one click.
Of course I expected pictures of each of these steps too. I guess I'll just have to settle for less than perfection.
I might give it a go tonight. I'm a little grubby after beginning my OSCAI work already. I am thinking of removing my JWT POP and doing the OSCAI, just to keep the noise down a bit. I figure by adding the y-pipe it'll get a little louder and I may want to quiet it down with the OSCAI.
Anyhow, thanks for the reminder.
Old Apr 13, 2001 | 11:08 PM
Y2KevSE's Avatar
LOL! I'll put instructions up right now.
Old Apr 13, 2001 | 11:52 PM
Success!!!!!!
Kevin, Check out these pics!!! If you like them, you can use them on your site.
Old Apr 13, 2001 | 11:53 PM
Y2KevSE's Avatar
Re: Success!!!!!!
Woohoo!!! That was quick, BTW!
Old Apr 13, 2001 | 11:54 PM
Pic #2.
Old Apr 13, 2001 | 11:56 PM
Y2KevSE's Avatar
Yeah! But you're not using a Nissan filter!
Now loosen the tension on the belt and swap it!
Piece of cake! Thanks for the help, Kevin.
Old Apr 13, 2001 | 11:59 PM
Y2KevSE's Avatar
No problem... this process is easier than taking off the starter and wedging the wheely thingy isn't it?
Old Apr 14, 2001 | 02:08 AM
Actually I removed a cover on the bottom side of the engine and wedged something in the flywheel there. The starter looked like a beeahtch!
RichMax
Jul 12, 2003 12:54 PM
DanSE
Feb 24, 2003 08:05 PM
ArcticMax
Apr 12, 2001 06:12 PM
