rattle/ping noise from engine
Old Oct 18, 2004 | 01:39 PM
yogi's Avatar
i just notied that...when the car has been standing for a while(if it's cold) first time when u start the car u will get ping/rattle noise coming from the engine...what could that be..???........it sounds like valve's are messing up or something... but again....i have no idea what that could be...it only does that when the car was standing for a while and it's its cold...
i have a 03 maxima with 19k miles
thanks
Old Oct 18, 2004 | 03:31 PM
yogi's Avatar
no ideas bummer
Old Oct 18, 2004 | 03:56 PM
maximadave's Avatar
detailerdaveb@gmail.com
thanks
Your best bet is to take it to your dealer.
Old Oct 18, 2004 | 04:45 PM
nysemt1's Avatar
i had the same problem here today in new york. I started up my car and it sound like the fan was hitting something. I dunno what it was but i'm bring my car in this weekend to the dealership
Old Oct 18, 2004 | 05:23 PM
Mike T's Avatar
ignotum per ignotius
lifter noise. Try using a one step lower viscosity oil in the colder months. And use synthetic if you aren't already. Mine will do the same thing from time to time, early in the mourning, if I use 10w-30 in cooler weather.
Old Oct 19, 2004 | 03:10 AM
AllGo's Avatar
the noise you are hearing is the VTC cams that just don't get the oil pressure they need immediately. Especially when the vehicle has been sitting and the oil has had time to drain out. This should only be for about 1 sec. anything longer and you may want to get the dealer to look at it. I know there was a TSB for this particular issue.
I know this is a different issue but I also hear a different sound, like when cranking at startup, and the torque converter is spinning up, I hear like a rattle/engagement very suddenly and withing 1-2 seconds of startup. Any ideas? Its not a serious issue I am sure but kinda annoying and makes the car feel cheap. I have 38k on my 2002 auto gle by the way.
Old Oct 19, 2004 | 07:54 AM
yogi's Avatar
yea...i`m about to switch to synthetic this oil change.....i figure that if it's going to continue i`ll just take to the dealer
thanks for the input
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
