Throttle body cleaner?
Old Oct 21, 2004 | 10:46 AM
EddiexAhn's Avatar
what throttle body cleaner do you guys use?
is there even a difference between manufacturers?
thanks.
Old Oct 21, 2004 | 10:48 AM
Virus's Avatar
I use Gunk
Old Oct 21, 2004 | 11:40 AM
GreenSeMax's Avatar
Gunk is the BIZZZOMB, engine bright is awesome too, you can trust GUNK to do what it says.
Old Oct 21, 2004 | 11:56 AM
spirilis's Avatar
what's that, GUNK up your engine?
j/k, I use GUNK Air Intake/Throttle Body cleaner or whatever it's called... it's good stuff. Beware: Like all acetone-based solvents, it leaves a strange smell in your nose for at least a day (or at least it does that to me...)
Old Oct 21, 2004 | 12:11 PM
DAP's Avatar
DAP
I use the STP. You spray it on and wipe it off. Look at the directions since some say spray in and run the engine. Spraying and wiping seems safer.
Old Oct 21, 2004 | 01:28 PM
SoonerFan's Avatar
Cletus
i use gunk
and to really clean it you have the clean the back too (behind the flap)
http://www.cardomain.com/memberpage/335422/8
Old Oct 21, 2004 | 02:13 PM
ToneG
is that what you would use to clean what they would call the "throttle bore"? is it the same thing as the throttle?
Old Oct 25, 2004 | 09:13 AM
nicks79's Avatar
you are not supposed to sniff that stuff. Its worse then glue.
Old Oct 25, 2004 | 09:21 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You are supposed to use it in your car, not in your nose...j/k
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
