Sea Foam, I just bought one... will post any changes.....
Old Oct 23, 2004 | 08:41 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
As the topic says.................
Old Oct 23, 2004 | 10:53 AM
MAXINXS's Avatar
Ok...........
Old Oct 23, 2004 | 03:57 PM
SoonerFan's Avatar
Cletus
wow...i started a trend
Old Oct 24, 2004 | 08:28 AM
Lontar1's Avatar
Yeap Soonerfan and I just did the Sea foam to my car and so far:
Maxima Se 2001,
1. Idle really smooth. From a rough one to a really smooth one
94 Toyota Corolla
1. Damn this car was in bad shape from the engine idle point, mechanically is in top sahpe. Has 110K and going strong, it is my daily commute to the office which is 500 miles per week. I just did to the car too, and Wow you can feel the engine "in idle" really smooth, will test it tomorrow going to the office.
Will keep updating the list today.... I'm taking the car "Max" out for a spin, but the engine feel GOOD and sounds better...... Ohh, if the idle is the only thing it fixes, It is well worth it.
Old Oct 24, 2004 | 08:50 AM
panda_1's Avatar
from the experienced users of seafoam. is it better than bg44k? how much of a diff did u notice befor and after?
Old Oct 24, 2004 | 09:15 AM
Lontar1's Avatar
BG44k is a piece of crap, I had use it in the past and noting. I pay close to $20 and it is crap. Sea Foam I paid $4.6 w/ tax and so far the idle is smooth, with BG44K NOTHING Happened
Old Oct 24, 2004 | 09:28 AM
SoonerFan's Avatar
Cletus
well they are for diffirent things!!!!
BG44K cleans the fuel system - lines, injectors, etc (and no it is not crap)
Seafoam is to clean the air system - intake manifold, etc.
you need to do both to clean out both systems.
Old Oct 24, 2004 | 09:52 AM
2MuchMAX4U's Avatar
Where did you buy the Sea Foam? I been reading about this stuff and want to give it a try. When you say it was like $5 is that everything you need to use it? Any pointers on using it? My guy at ProLube uses a cleaner that is applied in a canister that is attached to the brake booster vaccum, he sets the car at a higher idle and lets the canister empty into the system. Is this the same as sea foam?
Old Oct 24, 2004 | 10:00 AM
SoonerFan's Avatar
Cletus
here is all the info you need
http://forums.maxima.org/showthread.php?t=346574
Old Oct 24, 2004 | 11:35 AM
2MuchMAX4U's Avatar
Thanks for the direction sooner-
Old Oct 24, 2004 | 11:54 AM
custommaximaSE's Avatar
Originally Posted by soonerfan
Thanks soonerfan for the great info.
But i got one ? .I don't want to use BG44k to clean the fuel system ,can i use this seafoam to clean the fuel system .If yes i just need to add the seafoam in the gas tank.?
Old Oct 24, 2004 | 12:07 PM
SoonerFan's Avatar
Cletus
yes you can. use half the can for the manifold and pour the rest in the gas tank
Old Oct 24, 2004 | 01:57 PM
VMaximus02's Avatar
You need to use this product from B&G: http://shop.store.yahoo.com/wyattarp...i3000plus.html
for the upper manifold system. The B&G44K is for fuel system as had stated.
Old Oct 24, 2004 | 02:10 PM
WildmanAL's Avatar
My sister drives a Rodeo (00' w/ a horible oil consumption and 85K) that eats a quart of oil every 3K. I changed her spark plugs yesterday to help with her fluctuating idle. I want to use seafoam, but not sure if this will clean away too much making her oil leak worst. It's more than likely blow by and all the oil is just getting burning in the cylider then pushed out the exhaust.
Would anyone recommend seafoam for her? Her throttle body is pretty dirty as well.
Old Oct 24, 2004 | 04:29 PM
Lontar1's Avatar
Maxima Se 2001,
2. Fast acceleration, better ....
3. No more hesitation
4. Feels with more power
5. I have an auto and the shifting was stronger and smoother
6. No more pinging
7. No more knockin
94 Toyota Corolla
I just came back from ,my spin and would recommend this product to everyone. I like the feeling of having restore the car to what it was before, I will do the treatment again in a few weeks.......
Thanks Soonerfan for the product
Going back to the BG44K it is crap.... for the price... I rather use the Chevron Techron..... cheaper and works better.....
Old Oct 24, 2004 | 04:37 PM
ZIPPIN's Avatar
Mauja He Mauja
can you verify that the hose pointed by the red arrow is the correct one?
Old Oct 24, 2004 | 04:38 PM
Lontar1's Avatar
I'm not a mechanic.. and don't know about the product. The label says a lot of good thins but if I were you I would contact the manufacturer and see what they have to say (952) 938-4811 http://www.seafoamsales.com/contact.htm
Old Oct 24, 2004 | 04:39 PM
Lontar1's Avatar
Yes...................
Old Oct 24, 2004 | 04:41 PM
ZIPPIN's Avatar
Mauja He Mauja
so just take the hose off the right side and dip it in the cup??
thanks
Old Oct 24, 2004 | 04:42 PM
Lontar1's Avatar
You can use it even in your oil.... transmission, lawnmower..etc... gas tank. That's what the label says......
Old Oct 24, 2004 | 04:43 PM
Lontar1's Avatar
thanks
http://forums.maxima.org/showthread.php?t=346574 follow this.. Soonerfan wrote it..... easy to follow....
Old Oct 24, 2004 | 04:45 PM
Lontar1's Avatar
Autozone.. I tried Pepboys first but they dont carry it.......
In Orlando $4.6 w tax
Old Oct 24, 2004 | 04:54 PM
Lontar1's Avatar
http://www.seafoamsales.com/motorTuneUpTechGas.htm
This is from Sea Foam website....enjoy
Old Oct 24, 2004 | 05:22 PM
jmal's Avatar
Dayum! This sounds like some good stuff...might have to try some myself.
Old Oct 24, 2004 | 05:49 PM
WildmanAL's Avatar
Just did it on my sisters Rodeo and yeah that mother smoked pretty bad. She has all kinds of engine problems including a SES light. Sometime this week I'm going to hook up a computer to it and do some compression tests to see what is going on. My throttle body looked spotless so I'm going to hold back for at least alittle while before I do this to the max.
Old Oct 24, 2004 | 06:08 PM
ZIPPIN's Avatar
Mauja He Mauja
i am going to try this in a few. just bought it from advance auto..i will also use it for the fuel sys
Old Oct 24, 2004 | 07:13 PM
ZIPPIN's Avatar
Mauja He Mauja
Just did it. A lot of nasty smoke came out.
Problems:
SES-came on as soon as I re-started her.
During the first drive when I came to a stop light, it almost died on me. When I accelerated, it started back-firing like crazy. A few minutes later the back-firing/missing went away. I drove straight to AutoZone, and they were closed.
It may be that something was already wrong with her, and using SeaFoam pushed her over the edge...
Will post the code tomorrow...
Old Oct 24, 2004 | 07:55 PM
panda_1's Avatar
from the two previous posts, i dont know if i want to try it anymore.
Old Oct 24, 2004 | 08:07 PM
MY2000MAX's Avatar
same
Old Oct 24, 2004 | 08:28 PM
jmal's Avatar
Ouch...me neither...but then again....
Old Oct 24, 2004 | 08:31 PM
Puppetmaster's Avatar
C'mon... only one person tripped a CEL so far.... nothing to be so afraid of... it might be something totally unrelated... then again, I'll try to do it first before I say any more...
Old Oct 24, 2004 | 08:34 PM
S00NR1's Avatar
OU > *
I don't know that two bad experiences could keep me from using Seafoam because like they said, it could have just revealed an existing problem which could have caused more problems in the future. If you read all the threads about it in the fluids section, I am pretty confident that you will find that the satisfied customers far outnumber the unsatisfied.
Old Oct 24, 2004 | 08:38 PM
absolutely...
Old Oct 24, 2004 | 08:50 PM
panda_1's Avatar
still, there is a saying that says "it only takes one screw up to blow over a lifetime of good deeds." so seafoam may have helped millions of people, but ur only gonna remember bout the bad times.
Old Oct 24, 2004 | 08:53 PM
panda_1's Avatar
dont get me wrong if i am able to find the stuff locally i would be willing to try it, just carefully!!!
Old Oct 24, 2004 | 08:54 PM
Yeah don't worry, I know what you're sayin man, that's kinda what I'm gonna do too, when I get the time...
Old Oct 24, 2004 | 08:55 PM
WildmanAL's Avatar
My sister already had a SES light before I even did this to her car. Hopefully by Tuesday I'll totally understand why it went off in the first place. I'll ask some of my instructors at school about sea foam and their takes on carburator cleaner that is sucked in through a vacuum hose.
Old Oct 24, 2004 | 08:57 PM
VMaximus02's Avatar
There might be too much carbon deposits in his intake manifold and the seafoam clogged the exhaust valves with dissolved by-products. I think you guys should first run the product in the gas tank first. Then, do it with the vacuum line after 1 or 2 gas treatments. The vacuum procedures speed up the removal of carbon deposit process. If there are too much accumulation of carbon deposits, chances are you will see similar negative results as mentioned.
Old Oct 24, 2004 | 09:00 PM
panda_1's Avatar
out of curiousity can someone post the main ingredient in seafoam, i am curious to look it up and see its effect on other things.
Old Oct 24, 2004 | 09:10 PM
panda_1's Avatar
lol..... ill try it on my dads chevy first, if all goes well ill move onto moms car, then finally onto mine. if ima break soemthing ill find out before it enters my motor.
