Brakes...
Old Oct 24, 2004 | 03:35 PM
MisterLuisito's Avatar
Brakes...
How much should it cost me to get the brakes done on my car. I'm not trying to get ripped off.
Old Oct 24, 2004 | 03:58 PM
RAZORFISH228's Avatar
I believe its like $400 from the dealer. If you go locally, it will probably run you over $200.
But if you are handy, you can do it yourself which would save you a lot of money.
Old Oct 24, 2004 | 04:00 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
here in mass is $150 a side, fukk that..........DIY.............
Old Oct 24, 2004 | 04:58 PM
Thank you both. I am in New Jersey and alot of the shops around my way are shady. I'm not an idiot when it comes to cars. I know my stuff. But I am new to the 2002 Maxima. Thanks for the replies. Any users in NJ got different pricing information?
Old Oct 25, 2004 | 09:10 AM
MY2000MAX's Avatar
In brooklyn, the dealer wants 190 for front and like 180 for back. But some of the shops can do it for around 200 altogether.
Old Oct 25, 2004 | 09:36 AM
Yaco_Max's Avatar
Star Nissan wants $350 +TAX !!!!!!!!!!!! WTF.......... I did it myself..........
Old Oct 25, 2004 | 09:45 AM
jzwu's Avatar
Dealer in So. CA wants $440. What a rip-off!
Old Oct 25, 2004 | 09:48 AM
Puppetmaster's Avatar
Do it yourself... if ya need help get a buddy or some local .Org members...
Old Oct 25, 2004 | 10:04 AM
Yaco_Max's Avatar
what!!!!!!!!!!!!111
Yaquito will do it for $300 no tax and cash...jejejejej
Old Oct 25, 2004 | 12:13 PM
maseo77's Avatar
you need a special tool to turn the rear brakes rather than C-clamp the fronts. A little tricky and time consuming without the right tools
Old Oct 25, 2004 | 12:56 PM
'02 Style's Avatar
Ouch!!!!! If pads cost $70 (from the Nissan dealer) for the the front, and you have a good jack and some tools, I would definitely DIY!!!! It should take about 15 minutes a side, as the fronts are very easy to change on a 5th gen. I have done mine and a couple other peoples. The rears require a tool that you can pick up at SEARS for like $15. Once you get the tire off, there are only two other bolts (14mm i think) to take the caliper off. Pads snap in and out, then just use a c-clamp to reset the front calipers. Replace everything, then trun on the ignition, and pump the brake pedal (the first time it should go almost to the floor). After a few pumps (3-4) it should feel normal. The whole process should take no more than 45 minutes. And the best part is that you now got an extra $200 for mods. HAPPY MOTORING!
Old Oct 25, 2004 | 01:22 PM
maseo77's Avatar
what exactly is that tool from SEARS called? i need one
Old Oct 25, 2004 | 01:27 PM
'02 Style's Avatar
maseo77,
Good question...I can't remember what it is called. But it is basically a 1 inch cube shaped tool, designed to be used as a socket. It has six different sides. It should be in the section with car maintenence tools (filter tools, etc.) Hope that helps, I will look around to see if I can get something more specific.
****UPDATE****
Lisle Disc Brake Piston Tool
Sears item #00946344000 Mfr. model #28600
That should point you in the right direction!
Old Oct 25, 2004 | 09:07 PM
Originally Posted by '02 Style
****UPDATE****
Good to know...
Old Oct 26, 2004 | 08:35 AM
tkostiuk4's Avatar
Instead of buying the tool you could just use a pair of needle nose plyers. Just make sure you push hard and turn really slow!
Old Oct 26, 2004 | 08:51 AM
GBAUER's Avatar
I wouldn't do that on my car. If you go to Autozone, Advanced Auto, Pep Boys, Sears, or any other place where you can buy car tools, get one there. It is a universal tool that can be used on any car. I bought one and have used it on about every kind of car from Impreza's to Sables. Basically a 1/4" driver extension plugs into it. You place it over the caliper cylinder, turn and push. The cylinder will collaspe pretty easily.
I had a buddy try to cheat it once and it cost him a new rear caliper. Believe me, that was a little more expensive than the tool.
Old Oct 26, 2004 | 09:17 AM
tkostiuk4's Avatar
I was only kidding. Buy the tool, it works great.
Old Oct 26, 2004 | 10:25 AM
PTP's Avatar
PTP
maseo77,
****UPDATE****
Is this what the tool looks like?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Oct 26, 2004 | 11:06 AM
GBAUER's Avatar
Originally Posted by PTP
No. that's a bit set. here's one for $10. http://www.jcwhitney.com/webapp/wcs/...Id=-1&TID=1544
Old Oct 26, 2004 | 12:50 PM
03SE2HEAR's Avatar
So you only need this tool on the rear brakes? So just to clarify, use this tool to turn the pistons clockwise to get them to push back in? I'm about to dive into this after just purchasing my '03. I have drum brakes on the back of all my cars, so this is different.
Old Oct 30, 2004 | 11:24 AM
Thanks! You guys are the best. I called up a few local shops and found the lowest pricing to be $230. No rotor issues like I previously thought. I appreciate the help.
Old Oct 30, 2004 | 06:50 PM
njmaxseltd's Avatar
I install pads all the way around for $80 bucks (40/axel), labor only - you supply the pads.
That includes flushing your brake fluid.
Tom @
Proline Body & Chassis
545 River Drive
Elmwood Park, NJ 07407
201-398-1512
Old Oct 31, 2004 | 06:48 AM
Cool
Thanks. I'm definitely going to keep you in mind for the near future. I want to put some BIG brakes on my ride. I added you to my buddylist.
Old Oct 31, 2004 | 01:55 PM
How much for those?
Old Oct 31, 2004 | 03:09 PM
Originally Posted by TopElement
13.1" rotors and 4 piston, sequential bore calipers= $3200
14.5" rotors and 6 piston, sequential bore calipers= $3500
Kits also include SS lines, rear rotors and pads.
That's not bad. Can I order those from you or something? You sell them or what?
Old Oct 31, 2004 | 03:56 PM
Yes, the kit is an exlusive TET product.
Do you have these on your vehicle or do you have testimonials? I want to know what people think of them.
Old Oct 31, 2004 | 04:50 PM
Bl_asd's Avatar
it's laber only or including pads or rotors? what kind of rotors?
Old Oct 31, 2004 | 05:11 PM
WildmanAL's Avatar
My boss had all four rotors replaced along with new pads..... it ran him $600 from
Midas. I think he got ripped off. I told him he should have asked me and I could have done it for him for much less.
Old Oct 31, 2004 | 06:35 PM
I would definitely love to get the brakes for my car. Do I order them through you or a webpage? How much should I be charged for the install? I'm trying to get this done quickly.
redsox_max
May 6, 2013 09:37 AM
dynamicfigure
22
May 15, 2012 04:27 PM
Freaknificent
Apr 15, 2005 04:18 AM
nadir_s
Mar 29, 2003 10:29 PM
