P0171 - Fuel Injection System Too Lean
Old Oct 25, 2004 | 02:40 PM
mahvelus's Avatar
Hello,
P0171 - Fuel Injection System Too Lean (Bank 1)
Do you guys have any ideas what is the problem???
At my local garrage they had none :-)
Nissan Maxima 2k GLE
Old Oct 25, 2004 | 05:04 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
FSM says.....
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1 (front).
The ECM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios. In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the MIL (2 trip detection logic).
Possible Cause:
-Intake air leaks
-Heated oxygen sensor 1 (front)
-Injectors
-Exhaust gas leaks
-Incorrect fuel pressure
-Lack of fuel
-Mass air flow sensor
Old Oct 25, 2004 | 11:32 PM
mahvelus's Avatar
Thanks for your help :-)
What test do i have to do to know where exactly is the problem?
I went to to gar. and they didn't really know what to do, and i'm kind of tired of that service light soon!
Old Oct 26, 2004 | 03:59 AM
jmal's Avatar
MAF sensor...just had it done on Oct. 13th.
My SES light came on, codes P0171 & (eventually) P0174..fuel system lean bank 1&2. I had the dealer replace it...cost me $100 under my extended warrantee...and there was also an ECU update or reprogram involved. I didn't have any problems at first, besides more frequent 'pinging'...but as time went on, I lost acceleration power since the MAF sensor wasn't reading the airflow correctly...allowing less fuel, and then cold starts would be stalling and idling rough. All set now.
Old Oct 26, 2004 | 08:19 AM
mahvelus's Avatar
Thanks for your help!
Old Oct 27, 2004 | 03:25 AM
jmal's Avatar
No problem...glad I could help.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
