bose radio work with non bose
Old Nov 2, 2004 | 10:14 PM
ChromeSE5's Avatar
Curious if a bose stereo will work if i had a non bose stereo. I don't know if there are no factory amps inside the bose or if it is just a signal. This is specifically for 2k or 2k1. (i think)
Old Nov 3, 2004 | 10:18 AM
ChromeSE5's Avatar
bump ..........................
Old Nov 3, 2004 | 03:47 PM
cobymoby's Avatar
Yes it will work but you'll have to have separate amps to drive everything (you already knew that though).
Use the Bose stereo and use a AOEM-NIS2 which will give you RCA's out of the Bose deck. I have the AOEM's in stock. $39 shipped.
Old Nov 3, 2004 | 07:51 PM
brettb's Avatar
O'rly
Just so I get this right... need Bose, AOEM-NIS2, amp for front speakers and an amp for rear speakers?
Is the harness plug and play?
Old Nov 3, 2004 | 09:59 PM
roofadoofalus's Avatar
will the sound quality be the same?
Old Nov 3, 2004 | 10:03 PM
ChromeSE5's Avatar
im pretty sure it would because you are using aftermarket amps to power the speakers but i don't think the stock speakers could handle much.
Old Nov 4, 2004 | 12:36 AM
cobymoby's Avatar
Yes, that's correct. Harness is plug and play.
Old Nov 4, 2004 | 05:39 AM
sounds like a god deal
Old Nov 4, 2004 | 06:14 AM
brettb's Avatar
O'rly
Harness is plug and play minus the speaker wires though, since they need to be routed through the amps.
Maxinesdaddy
Aug 21, 2015 11:43 PM
carguy96
29
Aug 21, 2015 02:43 PM
