Window reset
Old Nov 3, 2004 | 03:59 AM
imxelite's Avatar
Window reset
I am trying to reset my auto-up feature from coming down everytime I roll it up.
I can't seem to find the little switch everyone is talking about. Could someone help me out? I took pictures to show what I'm looking at:
Old Nov 3, 2004 | 05:16 AM
thomwin's Avatar
Not sure about re-setting it.
I had mine replaced under warranty (switch and motor). It would roll down automatically as soon as it completed rolling up.
Old Nov 3, 2004 | 06:16 AM
Deckdout2's Avatar
Play with my balls
you have to feel it through the plastic towards the body shell, feels like a choke button on a push mower. let me see if i can find the thread for you
Old Nov 3, 2004 | 06:19 AM
Deckdout2's Avatar
Play with my balls
http://forums.maxima.org/showthread.php?t=319568
here you go
Old Nov 3, 2004 | 09:27 AM
rule da road's Avatar
try cutting the plastic a couple of inches to the right. Mine was so dark I couldnt see therefore feel what i was looking for
Old Nov 4, 2004 | 05:50 PM
imxelite's Avatar
I had my door panel open but I can't seem to find the black switch
Old Nov 4, 2004 | 07:19 PM
wavedog's Avatar
Look for a rubber button outlined in red. (about 3-4 inches left of the speaker)
Look inside towards the front bottom of the door behind the plastic vapour barrier you will see a small black switch. It
almost looks like a black pan screw head. This is the reset switch but there is a sequence to now doing the actual reset
procedure. The switch doesn't really feel like one when you press it through the plastic liner which incidentally you don't
need to cut (at least I didn't have to). It is a switch that is only on when you are pressing it otherwise when released
it is off.
REDinLV
Aug 15, 2024 12:30 AM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
