Hids more yellow than other maximas.Why?
Old Nov 5, 2004 | 06:48 PM
ZIPPIN's Avatar
Mauja He Mauja
I have noticed in a lot of 2k2+2k3 maximas, that their HIDS are much more bright and white than mine. I did not ground mine. Could that be the reason? In not, what else may cause that?
BTW: I have the OEM bulbs...
Old Nov 5, 2004 | 07:18 PM
Qmax03
same here i noticed some have even a little blue shade mine are kinda yellowish.
Old Nov 5, 2004 | 07:40 PM
ZIPPIN's Avatar
Mauja He Mauja
it's a mystery
Old Nov 5, 2004 | 09:49 PM
Loe max's Avatar
You could try grounding them to see if that makes a difference. Otherwise, HID bulbs 'wear' out (so to speak) so with age, the bulb emits a more purple hue and gets more purple as time passes.
Old Nov 5, 2004 | 10:36 PM
crispykid717's Avatar
Bigger than Jesus
I thought HID bulbs turn red when they burn out?? Mine are more blue/purple when I first turn them on and I can only see yellow in them from up close after they have been on a while. From far away they look whitish blue though.
Old Nov 6, 2004 | 07:20 AM
ZIPPIN's Avatar
Mauja He Mauja
exactly what happens to mine. they are almost a blue tint when first turned-on, then they kinda turn yellow.
Old Nov 6, 2004 | 07:25 AM
spirilis's Avatar
Did you convert or something? (your small profile below your avatar says 2000)
Old Nov 6, 2004 | 07:27 AM
ZIPPIN's Avatar
Mauja He Mauja
yes i did. it is been recently that i have noticed that they are yellow as compared to other maximas i see
Old Nov 6, 2004 | 07:38 AM
TrexMax001's Avatar
My stock HID's were ugly!!
I put 8000K in my low beams and 6000K in my fogs. Let there be LIGHT !!!!
Old Nov 6, 2004 | 07:47 AM
ZIPPIN's Avatar
Mauja He Mauja
anyone running 6000K low's here? I want to see if they will match the XTEC kit
Old Nov 6, 2004 | 08:02 AM
TrexMax001's Avatar
I don't "think" there is a 6000K D2R bulb. But even if there is, the reflectors in the headlights are completely different than those in the fogs, so unfortunately you won't be able to get an exact match.
When I run with just my DDE's and fogs, the fogs have a blue tint to them. When I have the headlights on with the fogs, the headlights look blue and the fogs look "whiter".
Just for ***** and giggles I put PIAA Xtreme whites in my highbeams. hahahahaha....the PIAA's look golden brown next to my headlights. My son says it makes the car look mean, I think it just looks damn near stupid.
I wish there was a perfect match, but so far I have had no luck.
Trex
Old Nov 6, 2004 | 01:46 PM
WildmanAL's Avatar
Why didn't you ground the HIDS? Yes they WILL be dimmer by not grounding them properly. Make sure you don't ground them on top of paint, but on bare metal. A lady came into the shop the other day and had a dim blinker.... ended up being that the ground was loose and when you secured it her blinker came back bright.
Old Nov 6, 2004 | 06:12 PM
Ammi's Avatar
350 Detroit Muscle
There are 6000K D2Rs
Old Nov 6, 2004 | 06:51 PM
00MaxSE's Avatar
Pointy Elbows
Phillips Ultinon are 6000K D2R. But they are expensive!
Old Nov 6, 2004 | 06:52 PM
Ammi's Avatar
350 Detroit Muscle
There are other brands that are cheaper
Old Nov 6, 2004 | 06:59 PM
00MaxSE's Avatar
Pointy Elbows
Yeah, but most of the other brands don't come with the U-shaped masking on the bulb. I had the KOPS 6000K and they didn't have it. Need it to keep the glare to a minimum.
Old Nov 6, 2004 | 09:26 PM
Loe max's Avatar
Nah, maybe when its about to die on you, but over months, the arc emits a more purple hue vs. new
Old Nov 7, 2004 | 07:12 AM
ZIPPIN's Avatar
Mauja He Mauja
jason, she is looking sweet
Old Nov 7, 2004 | 07:13 AM
ZIPPIN's Avatar
Mauja He Mauja
do you have web address for them?
thanks
Ammi's Avatar
350 Detroit Muscle
I got a picture of 6000K fogs if you want
Old Nov 7, 2004 | 07:18 AM
ZIPPIN's Avatar
Mauja He Mauja
i have the 6K fogs. looking for a pic of 6K low beams
Old Nov 7, 2004 | 07:30 AM
Ammi's Avatar
350 Detroit Muscle
Ah.........
Old Nov 7, 2004 | 08:01 PM
00MaxSE's Avatar
Pointy Elbows
Thanks Jay.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Fbana41
Aug 29, 2016 12:18 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
