New to the VQ: Have Mass Air Flow issues. HELP!
Old Nov 9, 2004 | 06:31 PM
attomica
Hello,
I have a 2000 Infiniti I30t and after spending some time at the stealership, I have learned that my Mass Air Flow Sensor is faulty. So, I would be grateful for the expertise of you who know the VQ. Here're my questions:
1. Is there any way a faulty MAF would not show an error code? Apparently, it didn't show up.
2. Is a Mass Air Flow Sensor the same thing as an Air Flow Meter?
3. Is it difficult to replace this component?
4. Any suggestions on where I can find a new one inexpensively?
It'll be nice to get this fixed and avoid the exorbitant costs at the stealership.
Thanks.
Old Nov 9, 2004 | 06:35 PM
nailz420's Avatar
1. if your check engine light was disconnected
2. yes
3. no
4. Dave B
Old Nov 9, 2004 | 06:36 PM
spirilis's Avatar
it's conceivable for the MAF to malfunction without tripping the ECU off enough to throw a code... eventually it would though.
Old Nov 9, 2004 | 06:49 PM
attomica
Originally Posted by nailz420
4. Dave B
Contact info?
Old Nov 9, 2004 | 07:01 PM
nailz420's Avatar
Originally Posted by attomica
Contact info?
http://forums.maxima.org/member.php?u=234
Old Nov 9, 2004 | 07:12 PM
ZIPPIN's Avatar
Mauja He Mauja
ken (jerry rome) is cheaper than baveb
Old Nov 10, 2004 | 05:42 AM
Matt_01SE_20th's Avatar
1. my MAF was F***ed up for like 6 months and bad too. i had like no power between 3k-5k rpm. the light never came on and the voltage was fine when i tested the MAF.
2. yes
3. no. but you may have to get the ECU reprogramed and thats like 2 hours of labor at the dealership and you need special equipment to do it on your own (anyone know any more about this procedure?)
4. no idea
Old Nov 10, 2004 | 11:49 AM
attomica
Originally Posted by Matt_01SE_20th
...you may have to get the ECU reprogramed and thats like 2 hours of labor at the dealership and you need special equipment to do it on your own (anyone know any more about this procedure?)...
Thanks Matt. Under what conditions do think the ECU would need reprogramming? I was hoping that it would be a simple matter of replacing the AFM and that would be it.
Old Nov 10, 2004 | 12:22 PM
Trance Artur's Avatar
www.jerryromenissan.com if ordering from there use the promotional code "maxima" to get a 12% discount.
Old Nov 10, 2004 | 12:40 PM
Cutler's Avatar
For you maybe , But I will bet Dave knows more about the parts business....
Cutler's Avatar
DaveB gives 25%
Old Nov 10, 2004 | 01:28 PM
ZIPPIN's Avatar
Mauja He Mauja
whatever. maf was cheaper from jerryrome
Old Nov 10, 2004 | 01:33 PM
Cutler's Avatar
Whatever is exactly right.... Take a poll and see where people prefer...
Regardless, what were the price differences so others can know?
Old Nov 10, 2004 | 02:04 PM
chinaonnitrous1's Avatar
MAF SENSOR FOR 2k/2k1 maxima/i30, for sale 60 bucks shipped. OBO.
Old Nov 10, 2004 | 02:36 PM
attomica
Well, "Who is cheaper" is a moot point now. I ordered one from daveb this morning. Now, can anyone talk about why the ECU would need reprogramming after the MAF replacement? Is it absolutely necessary?
Old Nov 10, 2004 | 04:12 PM
Cutler's Avatar
Wisechoice
Old Nov 10, 2004 | 04:42 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
I have a light hesitation when I let off the gas and then get back on, the only thing im thinking is MAF, NO CEL. Anyones car do this?
Old Nov 10, 2004 | 04:53 PM
Ammi's Avatar
350 Detroit Muscle
Anyone know the part number off hand?
Old Nov 10, 2004 | 06:45 PM
sascuderi's Avatar
I have never been able to find out why the ECU should be reprogramed. When I replaced my MAF last year I did not bring it to the dealer to be reprogramed. I just unhooked the neg. battery terminal while I replaced the MAF, then hooked the battery back up. No problems since.
Old Nov 10, 2004 | 07:14 PM
nailz420's Avatar
The TSB on the MAF issue has ECU reprogramming as the final step. As I read before, MAF's hot wire's temperature is controlled by the ECU. Since its a new part(new MAF installed has a different part number), ECU needs new instructions on how much to heat up the wire and how to interpret the new readings. The new MAF will work without reprogramming, but I also read that it is more likely to go out again soon.
Old Nov 11, 2004 | 03:32 AM
attomica
Meter-Air Flow, part# 22680-2Y001
Old Nov 14, 2004 | 07:29 PM
attomica
Okay, for those who care, I got this problem resolved. I ordered the part from daveb. The cost, including shipping and tax was $94.95. The replacement of the part is pretty straight-forward. You only have to remove the airbox, which is easy with only five bolts and one hose clamp to manipulate. I did disconnect the negative battery clamp to allow the ECU to reset. As it turns out, a Mass Airflow Sensor and an Air Flow Meter are the same thing. They have the same part number. After I got the replacement done, the behavior of the car was dramatically improved. Acceleration is much stronger and sharper. The stealership wanted to shank me for $450, so being able to do this myself was nice. Thanks daveb!
Old Nov 15, 2004 | 07:02 AM
desperado_45's Avatar
Everyone calls it a MAF but its really MAS
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
leatherneck
Sep 30, 2015 09:16 PM
