WE GOT CODES.. Dammit
Old Nov 11, 2004 | 12:05 PM
I30swimmer's Avatar
ok so any help on the topic would be great.. my SES light has been on for a while and i finnaly went and got it read today
P0171- System to lean bank 1
P0174- system to lean bank 2
ok so how do i make the mixture richer can i turn a screw and make it a bit richer? or do i have to accutally get a mechanic to fix stuff
Old Nov 11, 2004 | 12:21 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Per the FSM....
Possible Causes:
Intake air leaks
Heated oxygen sensor 1 (front)
Injectors
Exhaust gas leaks
Incorrect fuel pressure
Lack of fuel
Mass air flow sensor
I'd check your fuel pressure and then replace your MAF.
Old Nov 11, 2004 | 12:51 PM
I30swimmer's Avatar
is there any way to adjust the Fuel spray into my cilinders? with just like a small turn of a screw or somthing?
Old Nov 11, 2004 | 12:52 PM
I30swimmer's Avatar
it could be my MAF because it has 80k miles on the same one. so time to replace? maybe.. still want other ideas if you got them
Old Nov 11, 2004 | 12:58 PM
IceY2K1's Avatar
You have any other mods besides your eCutout?
Have you messed with the intake?
Old Nov 11, 2004 | 01:41 PM
I30swimmer's Avatar
ehh i have a K&N filter and holes drilled in the Air box.. but i have had the holes for nearly 10,000 miles with no problems and the K&N i have had for 5000 miles. and never had any problems before.
The only thing i can think that has changed is the type of gas i have put in the last two times. Two tanks of Regular after MANY tanks of premium so that may be causeing my issues, well thats what happens when my dad decides to go get gas for me to be nice.
Old Nov 11, 2004 | 01:46 PM
IceY2K1's Avatar
I'd uninstall your whole intake looking for air leaks and check your MAF to see if it's oily.
Those two codes are LONG TERM issues. Basically, the ECU has been trying to correct for the lean condition, but the maximum has been exceeded and it can't correct any further.
Old Nov 11, 2004 | 04:54 PM
I30swimmer's Avatar
Ahh we have no more codes .. i ripped apart my intake setup. cleaned my throttle body sprayed lots of cleaner into the manifold. and messed around with my VAIS. got it tuned to open at around 4850 rpm a little earlier than normal .. low and behold Codes are gone when i turned her over.. havent gotten to drive her yet but we shall see if the are gone for good.
Old Nov 12, 2004 | 12:22 AM
jmal's Avatar
I had both of those codes too and a new MAF sensor fixed it.
Old Nov 12, 2004 | 08:00 AM
IceY2K1's Avatar
How? ...........
....messed around with my VAIS. got it tuned to open at around 4850 rpm a little earlier than normal.
Wasim521
Jan 2, 2003 03:12 PM
Yossarian
Jun 1, 2002 07:33 PM
Llfe
Jan 15, 2002 01:19 AM
MidnightSpeed53
Nov 13, 2000 05:31 PM
